Author Topic: USB hub, mouse devices changing ID on bootup?  (Read 1048 times)
fatfingers
  • Got UltraStiks?™
« on: November 07, 2006, 07:25:36 pm »
Hi.
I am having difficulties with my mouse devices (Happ Trackball, SlikStik spinner) after rebooting my machine.  I have them (and my two UltraStiks which seem to be fine) plugged into an El Cheapo TM non self-powered 4 port USB hub (UltraStiks in ports 1 and 2, spinner and trackball in 3 and 4).  I also have a standard mouse attached via USB (no hub) into my motherboard.
The problem I am having is that it seems on reboots I do not get the same "mouse id" for MAME.  In other words, if I set mame global inputs for spinners and trackballs and then reboot, it seems I may or may not get the same "mouse id" next time and I may have to re-set the mame inputs to be the current settings.
Any help here?  Am I just stupid?  Do I need a powered hub?  Should I not use a hub?  Should I take up cross-stitching?
 :dunno
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
NickG
  • Last login:September 27, 2025, 08:06:19 am
  • Dig.
    • My Projects Page
Re: USB hub, mouse devices changing ID on bootup?
« Reply #1 on: November 07, 2006, 09:57:31 pm »
There is a better solution, but if your motherboard supports hibernation, you could just hibernate your system instead of shutting down/restarting once you have completely configured your system.  Upon recovering from hibernation your system should be exactly as you have left it.  It is faster than a full startup, also.
RetroBorg
  • Last login:September 15, 2025, 06:25:47 am
« Reply #2 on: November 08, 2006, 02:53:58 am »
 :dunno
You should take up cross-stitching.  ;)
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #3 on: November 08, 2006, 04:37:35 am »
Or you need a couple Electric ICE-T™ Deluxe RGB Arcade Trackballs.  These trackballs remember which number they are so that player 1 is always player 1 and player 2 is always player 2.  I would think that trackballs 3 & 4 would do the same (be players 3 & 4) but I only own two of these trackballs.  Being able to light them up whatever color you want is just icing on the cake...
