Author Topic: Replicating A Mame Setup  (Read 1438 times)
Roughy
  • Last login:July 01, 2009, 09:33:20 pm
  • Easily impressed.
    • UserGlue
« on: November 02, 2006, 08:01:34 pm »
I feel kind of weak just for asking this, but I kinda have to.
It's been over a year since I built my cab--and I've come into a second one for a song.  I've just picked-up a dirt cheap box from Fry's (even had XP Home on it) and I want to (basically) replicate the EXACT setup that is on my existing cabinet box.
All the settings (except that the new box may have a different keyboard mapper), the GUI, the ROMs, etc.
I'd love to think it's as simple as "copy (all of this) to <location (disk, network, etc.)>, copy to <new machine>, DONE!" but I'm guessing it's not.
And, I'm posting this as I begin to do the work, so I'm kinda a bit bad about it all, but my luck isn't so good as to have it work that way.
Any advices or suggestions?
somunny
  • Is it hot in here?
Re: Replicating A Mame Setup
« Reply #1 on: November 02, 2006, 08:33:12 pm »
That's what I did.  I partitioned the hard drive and labeled it the same as my original mame drive (e:).  Then just copied everything over.  There were a few little tweaks needed but otherwise it was totally painless.
BamBam
  • Last login:November 03, 2011, 07:18:19 am
  • This is better than Disney Land man!
« Reply #2 on: November 02, 2006, 09:16:45 pm »
Just copy it.  I do all my graphics work and Mame tweaking on my main computer and then copy it to my arcade.  Just make sure that the path is the same ie. C:\mame.  If you copy it to a different drive letter, you will have to ammend the mame.ini accordingly.
Galaga... Was there any other game?
spacies
« Reply #3 on: November 02, 2006, 09:22:30 pm »
Yip, just copy it all.
If you run MAMEWAH you will need to run the system file again on the new PC.
jelwell
  • Last login:December 24, 2014, 03:47:21 pm
« Reply #4 on: November 03, 2006, 03:04:40 pm »
You're going to lose any Windows settings/changes, especially any work you've done to hide windows. You could try Ghosting it. Although if your motherboard/cpu is different you're likely to cause more problems than you'd solve.
Joseph Elwell.
eccs19
  • Last login:April 20, 2021, 10:36:08 am
  • Just plugin away!
« Reply #5 on: November 04, 2006, 07:36:06 pm »
Joseph Elwell.
Agreed, if your just copying Mame, then you should be fine, but if your planning on copying the OS, then unless the 2 computers are identical models, Windows will need at LEAST a repair install, and if all goes well, then you should be good to go, but even with extreme hardware changes, a repair install still may not work.
Working - Mr. Do! - Neo Geo 4 Slot - Bartop Mame
Project(s) - Pacman
Bill Mote
  • Last login:May 29, 2010, 11:04:28 pm
  • Focus on making things better not bigger.
    • Things That Make Me Mad and How To Fix Them
« Reply #6 on: November 05, 2006, 07:51:53 am »
If you're wanting to get a 1:1 copy of everything then you can use Ghost as well as a utility on the XP CD called "sysprep."  It's in the support folder inside a cab file named deploy.  If you have Ghost then that's a valid option.  Syspreg guts the machine of all it's hardware specific settings and forces the machine through mini-setup (enter your key, machine name, etc.)
I seperated my OS from my MAME stuff so that I could capture periodic (as major changes happen) ghosts of the OS.  The MAME stuff I backup excluding the ROMS, SNAPS, etc. folders.
dot
