March 20, 2026, 10:46:27 pm
Right now with the actuator set like I drew it in the picture. I am hitting one at a time. However, when I hit a perfect diagnol no switch gets hit?
In diagonal it should hit one switch, but never two. Hitting two switches will actually cancel each other out in a 4way game, and neither switch will register. I'm not the one to be giving advice, though. I don't have mine in front of me.For future reference, loosen the clip by wedging a screw driver under it. You'll save your fingers a world of pain. (Just make sure it doesn't go flying. You can do that by putting a plastic bag over it while you take it off.)
First off, Hoopz is right.
Home Depot only has A,B,C,D,F,G,H,I,J,K,L,M,N,O,P,Q,R,S,T,U,V,W,X,Y,Z clips.
Kremmit tell me this though. On the activator what end would you face down the wider end or the narrow end. Tornado Terry told me to put the narrow end down. The wider end down is how I have it set in the picture/
Quote from: rdowdy95 on November 01, 2006, 02:02:14 pmKremmit tell me this though. On the activator what end would you face down the wider end or the narrow end. Tornado Terry told me to put the narrow end down. The wider end down is how I have it set in the picture/The narrow end is "down" or closer to the e-clip on mine and I haven't had any problems with mine. Trust Terry.
