Author Topic: MAMEWAH Set-up problem  (Read 2722 times)
MAME nut
  • Last login:March 18, 2024, 12:33:01 am
« on: October 25, 2006, 10:42:55 pm »
Sort of embarassing.....I wanted to copy my files and set-up from a machine I built two years ago (that works perfectly), but MAMEWAH locks up at start-up with this message in the LOG.... (any help would be appreciated of where to begin trouble shooting, THANKS)....
10/25/06 9:03:10 AM MAMEWAH launched
10/25/06 9:03:10 AM Desktop colour: 8421376
10/25/06 9:03:10 AM Wallpaper filename: (None)
10/25/06 9:03:10 AM Display mode: 640x480 @ 0Hz, 8 bit colour
10/25/06 9:03:10 AM Decimal symbol: '.'
10/25/06 9:03:11 AM Layout selected: C:\MAMEWAH\layouts\Caveskin\layout.lay
10/25/06 9:03:11 AM Bad image file: C:\MAMEWAH\layouts\mamewah-art.png
10/25/06 9:03:11 AM Error: 429 ActiveX component can't create object in CTRLR_InitialiseDI
10/25/06 9:03:11 AM Error: 429 ActiveX component can't create object in SFX_InitialiseDS
Brad
  • Last login:August 03, 2018, 05:43:23 pm
    • www.emuchrist.org
Re: MAMEWAH Set-up problem
« Reply #1 on: October 25, 2006, 11:20:41 pm »
DirectX possibly?
Brad
headkaze
  • 0x2b|~0x2b?
« Reply #2 on: October 26, 2006, 12:14:43 am »
Looks more like an unregistered Active X control (ocx). If MameWah comes with an installer I suggest you use it. If you just copied the folder across to your other machine then some components that need to be registered during install are missed. I would (1) Install MameWah using it's installer then (2) Copy the folder from the setup machine over it.
jcrouse
  • Last login:January 09, 2010, 05:53:51 pm
    • CPViewer
« Reply #3 on: October 26, 2006, 07:31:39 am »
As Headcaze stated, make sure you have installed the MameWAH Sysyem Files which are available for download on the MameWAH website. Also, make sure you have at least DirectX 7 (I think). Just install the latest DX.
John
Bill Mote
  • Last login:May 29, 2010, 11:04:28 pm
  • Focus on making things better not bigger.
    • Things That Make Me Mad and How To Fix Them
« Reply #4 on: October 26, 2006, 08:00:55 am »
It's a DirectX or audio driver problem as I recall (as previously suggested.)  I had this very same problem when I setup my first MAME box.
Here's a previous thread: http://forum.arcadecontrols.com/index.php?topic=39912.msg360649#msg360649
dot
