Author Topic: XBox light gun ???"s  (Read 1885 times)
taternutz
  • Last login:June 15, 2011, 08:47:22 pm
  • lovin tots since 78
« on: October 19, 2006, 07:50:56 pm »
Can these be modified like the controllers to run off of usb and work with mame??? :dizzy:
DarkBubble
Re: XBox light gun ???"s
« Reply #1 on: October 20, 2006, 10:43:01 am »
Even though the Xbox controllers are basically USB, there's some tweaks here and there that make it necessary to install an extra driver for support.  Whether or not that driver would allow a gun to function in Mame, I'm not sure.
versapak
  • I am t3h GAY!!!
« Reply #2 on: October 20, 2006, 11:29:06 am »
Xbox USB has an extra wire (the yellow one). In order to convert Xbox controllers to be used on the PC, you just put a regular USB plug onto them, and leave off that extra wire.
Why an extra wire?
Well it just so happens the ONLY controllers to use that extra wire are lightguns. This unfortunately means that they can not be converted to the standard 4 wire PC USB. :(
taternutz
« Reply #3 on: October 20, 2006, 06:49:37 pm »
thx guys, is there a cheap way to get a light gun?
DarkBubble
« Reply #4 on: October 23, 2006, 11:13:58 am »
You can interface a GunCon with MAME.  I can't seem to find the correct info, as all the links are dead.  There's drivers for it, and I assume that you'd use a Playstation-to-USB adapter for the interface.  Originally, only TV and arcade monitors were supported, but CRT PC monitor support was added later.  It looks like PC monitors require you to be really close though, but I can't say for certain.  Try searching the Main board.
slycrel
  • Last login:June 25, 2025, 07:42:34 pm
  • Mmm... Portal.
« Reply #5 on: October 25, 2006, 04:26:58 pm »
Report back here if you get something working please.  I've not dared take the plunge yet because I've not heard any really great experiences with xbox light guns and emulation on the xbox.
Khenemet Heru
  • Last login:November 10, 2018, 06:27:09 pm
  • I want him in the games until he dies playing.
« Reply #6 on: November 21, 2006, 03:31:06 pm »
here's a page for the Guncon2 to PC driver etc. that's working...
http://www.guncon2driver.com/
only thing is, I think you need a PS2 to USB adapter also; everything I've read says the XBox guns won't work, so this seems to be our only  option besides the playasia guns.
No Boom today. Boom tomorrow. There's ALWAYS a Boom tomorrow. - Cdr. Susan Ivanova, Babylon 5
