Author Topic: arcade vga and jpac  (Read 1134 times)
philby85
  • Last login:August 28, 2008, 08:25:17 pm
arcade vga and jpac
« on: October 17, 2006, 11:23:36 pm »
Hi everyone,
I just bought a neo geo cab which is also wired for jamma. the jamma connector from the cab only connects to the larger row of pins on the j pac. there's nothing to connect to the smaller row of pins on the  j pac. When I connect vga to the jpac I get nothing on the screen at all. the sync ok and sync in light up ok. if I connect to a pc monitor via the dvi out I get a pic on the pc monitor but the sync ok light goes out.
Is the jamma connector on the cab not quite right? I have emailed Andy at ultimarc. I just thought one of you guys might know.
cheers
Philby
johnm160
  • Last login:April 09, 2024, 09:00:46 pm
Re: arcade vga and jpac
« Reply #1 on: October 17, 2006, 11:28:03 pm »
Photos please
philby85
« Reply #2 on: October 17, 2006, 11:49:23 pm »
Hi john,
thanks, here are some pics let me know if I you need others. Thanks for helping.
philby
johnm160
« Reply #3 on: October 18, 2006, 08:42:26 am »
Hi john,
philby
OK,
that is not a full jamma harness. they used a similar connector to connect in there credit / options board or what ever that thing is that is in the first pic.
A full jamma harness will have a bunch more wires and fill up your connector.
Here is a good link to see what is involved in putting in a full jamma harness.
http://arcadecontrols.com/BBBB/jh.html
« Last Edit: October 18, 2006, 08:51:58 am by johnm160 »
