Author Topic: Neat wiring job question  (Read 8143 times)
fatfingers
  • Last login:April 17, 2025, 05:26:08 pm
  • Got UltraStiks?™
« on: October 10, 2006, 03:23:21 pm »
Hello.  I understand how to wire my control panel.  What I do not understand is how to do it neatly.  I'm even willing to give up on the neatly part, if someone would just give me an idea of what they use to "attach" the wires to the control panel so they are not hanging loose?  I have cable ties, but even if I use those, the tied wires still hang loose.
Thanks for any and all suggestions!
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
W.W.P.M.D.?                                       I'm here to help ... I just don't do it. ™
Re: Neat wiring job question
« Reply #1 on: October 10, 2006, 03:27:43 pm »
start by using cable clamps...Cheap and easy to find at almost any hardware store or even at a walmart.
just slip in the wires and screw down
gamecreature
  • Last login:October 29, 2008, 08:35:37 pm
  • I'm making this up as I go along.
    • Gamecreature
« Reply #2 on: October 10, 2006, 03:28:37 pm »
Or just staple the cable ties to your board.
Make your cabinet look its best with custom art from
Gamecreature!
spacies
« Reply #3 on: October 10, 2006, 03:30:14 pm »
Those are a good solution. Here we call them 'P' clips.
ahofle
    • Arcade Ambience Project
« Reply #4 on: October 10, 2006, 03:38:23 pm »
I used 8 conductor wrapped cable and a staple gun to attach to the CP and it still looks messy.  But my wife says I am a slob, so....   :dunno
Lewis Black
  • Last login:October 17, 2012, 08:14:10 am
  • Baaaah Eff it!
« Reply #5 on: October 10, 2006, 03:39:42 pm »
Also these can be found in the aisle by nylon ties.
Dervacumen
  • Last login:June 12, 2024, 01:58:21 am
  • Home of Three Squares dice game
    • Beaker Games
« Reply #6 on: October 10, 2006, 04:22:43 pm »
I used the cable clamps.  Last time I tried stapling wires I either shot the staple into some or stapled it with such force that I broke the wire in two.
Bringing to life a child's imagination.
Stingray
« Reply #7 on: October 10, 2006, 04:28:49 pm »
FYI, Bob Roberts stocks these. Not really worth buying them from him if that's all you need, but if you're ordering some stuff anyway toss a package or two in with the order.
-S
original_maxlamer
  • Last login:November 08, 2007, 08:39:00 am
« Reply #8 on: October 11, 2006, 06:29:15 am »
I would recommend stapling the cable ties to the board BEFORE tieing the cables with them (hope that made sense)  :dizzy: to avoid................
which leads to short circuits  :blah:
daywane
  • GRRRR!
« Reply #9 on: October 11, 2006, 08:37:57 am »
If you have a dollar tree or dollar eagle in you neck of the woods
those are sold for $1.00 for 20 pieces in a bag
arzoo
  • Last login:January 26, 2025, 08:51:53 am
  • Robots WILL kill you.
    • LEDBlinky
« Reply #10 on: October 11, 2006, 09:19:22 am »
I used a combination of p-clips and tie-wraps. Here’s a trick you can do with the tie-wraps to keep the wires secured – before clipping off the extra length, use a staple gun to attach the leg of the tie-wrap to the cp. If the staple isn’t tight against the wrap, you can loop it through one time. Here’s a picture of some of my wiring. If you look closely at the gray ribbon cables for the rgb LEDs, you can see how I did it.
Robots will kill you.
Arcade Addiction
Level42
« Reply #11 on: October 11, 2006, 10:40:54 am »
Even though not perfect yet (CP will be replaced), I think my wiring is pretty neat:
http://forum.arcadecontrols.com/index.php?topic=51119.0
whammoed
  • Last login:Yesterday at 09:09:52 am
  • Crack don't smoke itself
    • NiceMite
« Reply #12 on: October 11, 2006, 07:35:13 pm »
Yep, p clips and LOTS of cable ties to keep the wires bundled together.
Grauwulf
  • Last login:July 27, 2009, 03:42:44 pm
  • Button Masher
« Reply #13 on: October 11, 2006, 11:54:35 pm »
Excellent looking wiring job arzoo. I use the staple & zip tie method usually, with the odd 'p' clip thrown in where needed. Some materials don't take staples too well, so you have to us the clips. The biggest thing that will help keep your wiring neat is make sure it is secured well. And use zip ties on the branches of the harness to keep everything together and neat.
www.wolfelectronics.ca
Cap Kits for Canadians!
Burke LaShell
  • Last login:October 10, 2015, 06:45:05 pm
« Reply #14 on: October 12, 2006, 12:15:43 pm »
I used the wire clips you nail in and some cable ties.  Worked well for me.
  • Last login:Yesterday at 02:56:43 pm
« Reply #15 on: October 12, 2006, 12:21:11 pm »
What kind of wiring? Solid core or strand? What gauge?
I used solid core - 18-22 gauge:
While not perfect, it's fairly clean. The solid core allows you to bend it the way you want and it'll pretty much maintain it's shape. I'm curious how stranded and clips would work.
Banacek
  • Last login:November 08, 2017, 05:01:31 pm
« Reply #16 on: October 12, 2006, 12:44:47 pm »
Wow, your guys wiring jobs look so nice, I'm ashamed to show mine :) I used a mix of p-clips, staples, and that tubing you can get at any electric store. I have no idea what it's called.
johnm160
  • Last login:April 09, 2024, 09:00:46 pm
« Reply #17 on: October 12, 2006, 02:16:39 pm »
Neat wiring is the sign of a sick mind    :P
Grauwulf
  • Button Masher
« Reply #18 on: October 12, 2006, 06:03:27 pm »
It's called split loom here. I use that stuff a lot when I'm doing car wiring, makes things look nice and neat and it is an extra layer of protection for the wires.
jelwell
  • Last login:December 24, 2014, 03:47:21 pm
« Reply #19 on: October 12, 2006, 06:33:03 pm »
This might be obvious to most people, but:
You only need one ground wire coming out of your encoder, they can all run like christmas lights off the same wire, going in and out of each switch. You can see that in all the pictures above.
And yes, I *have* seen pictures of people who jammed one ground wire into their encoder for each switch - that becomes messy really quick.
Was that me on my first attempt? I can't remember and this picture is so frenzied that it's hard to tell if that's what I did (either way - don't do it):
Joseph Elwell.
arzoo
    • LEDBlinky
« Reply #20 on: October 13, 2006, 08:54:36 am »
Another (obvious) method for neat wiring is to use different color wire. Although it doesn't seem to have helped in the cp above!  :dizzy:
Arcade Addiction
ArcadEd
  • Last login:March 04, 2012, 01:25:15 am
  • Arcade-In-A-Box , Relive Your Childhood
    • Arcade-In-A-Box
« Reply #21 on: October 13, 2006, 06:00:16 pm »
These are the ones I like, the mounting tape ones, not the nail in.
johnm160
« Reply #22 on: October 13, 2006, 09:23:43 pm »
ArcadeEd,
What type of wire is that your using? It looks like the 25 pair phone lines.
ArcadEd
    • Arcade-In-A-Box
« Reply #23 on: October 13, 2006, 09:49:26 pm »
That's actually a Happ Jamma Harness.
For arcade box builds I just use 22gauge stranded wire.  Green, Red and blue.  Green for ground, red and blue for players 1 and 2.
I bundle pretty close to the same way though. :)
johnm160
« Reply #24 on: October 13, 2006, 10:00:07 pm »
I see, I thought that was too many colors to be the run of the mill home center stuff... ;D
