Author Topic: Help! Cant play MP3's in background of Game Launcher  (Read 2341 times)
Fat-Johnny
  • Last login:April 14, 2023, 09:23:33 am
« on: March 23, 2003, 06:49:15 pm »
Trying to do final customization on Game Launcher, but I cannot get it to play a MP3 file in the background.  Please help.
Known variables:
1) I have a file called
Fat-Johnny
Re:Help! Cant play MP3's in background of Game Launcher
« Reply #1 on: March 26, 2003, 07:34:50 am »
Bump.   Anyone???
FJ
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #2 on: March 26, 2003, 08:17:13 am »
Bump.   Anyone???
FJ
*shrug*
have you tried leaving playlist.txt in the glaunch directory (and  reverting the folder specification  for mp3_playlist_file =  to accomodate...)?  *shrug*
i'll go peek at my setup and see what's doing...
Also does sound work at ALL for you in glauncher.. i.e. do you get the little clicks when scrolling and the squaunk! sound effect when luanching a game?   you can have your playlist configged to the moon but if gl is having issues with your soundcard (which is? and which OS?) it'll be a moot point...
I had an issue once where MAME detected my soundcard fine, but glaunch wasn't....  (as they use different sound card detecting libraries...)
just some ideas...
rampy
EDIT: ok... my playlist.txt is in my glaunch directory and my config file looks ike this...
mp3_playlist_file = playlist.txt
And without fail twisted sister, Devo, and other 80's "hits" play in the background =P
good luck!
« Last Edit: March 26, 2003, 10:06:30 am by rampy »
Jakobud
  • Last login:December 23, 2025, 02:48:26 am
« Reply #3 on: March 26, 2003, 01:56:47 pm »
uummm....you say your 'mp3' file is named 'music.mpe' ?  Is that a typo?
rampy
  • *shrug*
« Reply #4 on: March 26, 2003, 02:03:08 pm »
I noticed that too.. but disregarded it... (but could be symptomatic of the possible issue =P )
rampy
Odonadon
  • Last login:January 27, 2006, 12:01:12 am
  • But then again, that's just one man's opinion.
    • Turbo2k
« Reply #5 on: March 26, 2003, 02:04:36 pm »
rampy
Doh!
Odonadon
It's Captain Odonadon, and his magical bag of nuts.
Fat-Johnny
« Reply #6 on: March 27, 2003, 07:38:20 am »
*shrug*
I have had another day to play with this, and I got it working (kinda).
Yes, GL was making sounds in the menu, so I knew that the sound was working and that GL could work with my card just fine.
It seems like I got a problem with my MP3's.  What I did is set up 12 MP3's in c:\glaunch\    I named them music01.mp3...thru...music12.mp3.  I then added 12 seperate lines to my playlist.txt (also located in C:\glaunch\).  I launched GL, and it started playing an MP3!!  The only problem is......it started with music03.mp3.
I started "remarking out" lines in playlist.txt (by inserting # in front of the line), and found that GL would only play certain MP3 files.  Started investigating for the obvious (VBR, very low bitrate, very high bitrate, etc..)  It seems that GL likes my 192 and 320 bitrate MP3's, but did not like my 128 and 160 bitrate files.  This held true, until it got to music12.mp3.  Music12 was a 160 bitrate, and it played fine (whereas all the other 160's did not play at all).  NOTE:  All of these MP3 files play fine in Musicmatch, Windows Media Player, and Cyberpunk's Virtual Jukebox (which I think uses WIndows Media Player).
It seems as if there IS a rhyme/reason to this, but I just dont know what it is yet  ;D
Any more thoughts, guys??   ???
Thanks for the help so far,
Fat Johnny
