Author Topic: Is my arcade cabinet power supply dead?  (Read 2022 times)
tribasic
  • Last login:August 19, 2013, 08:45:50 am
« on: September 30, 2006, 08:37:50 pm »
Hi everyone.
I'm having a problem with a generic arcade cabinet that I turned into a mame machine.
My cabinet is JAMMA and I'm using a J-PAC to interface my PC.
Today I noticed that the coin door lights were not working on it. So I decided to unhook my PC and plugged my Marvel vs Capcom board into it, but the board does not seem to be getting any power at all. And it used to work just fine.
A long time ago, I remember reading something about disconnecting the original power supply of the arcade machine before converting it to mame. I think it said something about the J-PAC not providing a sufficient load for the power supply or something, and it could cause the power supply to burn out. Anyhow, I know I didn't disconnect the original power supply when I mamed it.
So... Do you guys think I need a new power supply? And is a new power supply expensive?
Thanks for any insight into this (hopefully) minor problem.
TriBasic
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: Is my arcade cabinet power supply dead?
« Reply #1 on: September 30, 2006, 08:40:47 pm »
The JPac puts no load on the power supply, so it is entirely possible that it is now dead, but you should test it with a multimeter to find out for sure.
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
tribasic
« Reply #2 on: September 30, 2006, 08:50:33 pm »
Thanks for the advice CheffoJeffo. I'll buy a multimeter and test it out.
Also, thanks for such a speedy reply!!
TriBasic
CheffoJeffo
« Reply #3 on: October 01, 2006, 08:51:59 am »
If only my reply had been as detailed as the one you got from bish ... his was a higher-quality response.
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
tribasic
« Reply #4 on: October 01, 2006, 11:06:57 am »
hahaha
thanks again CheffoJeffo!
You knew about Bish's response to my message before I did! I just checked the other message forum and saw Bish's answer.
This is fun though. I get to learn a bit more about the inner workings of my cabinet! As soon as I get home tonight I'll be spending some quality time testing my power supply!
TriBasic
