Author Topic: How do I get games in MAME to run at a different frequency?  (Read 1813 times)
« on: September 28, 2006, 01:44:36 pm »
OK, I have the Happs Vision Pro VGA/SVGA monitor (http://www.happcontrols.com/monitors/491337vp2lg.htm) and some games give me an "out of range" error message when I try to play them.  Examples are Tapper, Popeye and Mortal Kombat II.  Is there any way to get these games playable on my monitor?  Is there a setting I can input for each game that is doing this so it will run in the proper range of my monitor?
THANK YOU!!!
« Last Edit: September 29, 2006, 11:07:27 am by javeryh »
Re: Can I force a game to run at a different frequency?
« Reply #1 on: September 28, 2006, 07:49:39 pm »
rtfm
you cand send the resolution and frequency for mame to use via command line.
« Reply #2 on: September 28, 2006, 10:21:53 pm »
rtfm
Thanks... for each game individually or mame as a whole?
« Reply #3 on: September 29, 2006, 10:40:55 am »
see below
« Last Edit: September 29, 2006, 01:36:38 pm by javeryh »
Re: How do I get games in MAME to run at a different frequency?
« Reply #4 on: September 29, 2006, 01:15:15 pm »
OK, I'm going to try and walk through an example...  I am running "mspacman" perfectly with no modifications or special configurations other than specifying "-ror" so it rotates 90 degrees.  According to MAWS, mspacman runs at a resolution of 224x288 and at a frequency of 60.606060Hz.  Everything works perfectly for this game.
I'm also trying to run "popeye" however I get an "out of range" error message on the monitor.  According to MAWS, popeye runs at a resolution of 512x448 and a frequency of 60.000000Hz.  How can I instruct my monitor to display this?
Would the command "-resolution 640x480" do the trick?
Any help would be MUCH appreciated.  THANKS!!
« Last Edit: September 29, 2006, 01:38:26 pm by javeryh »
« Reply #5 on: September 29, 2006, 10:06:27 pm »
Anyone??
« Reply #6 on: September 29, 2006, 11:16:26 pm »
yeah that'll work
You'll need 640x480@15 though if it's an arcade monitor.  For the record though It'd try a different resolution as 640x480 usually has to be interlaced to display on such a low frequency.
This might be a good question to ask over at ultimarc.
« Reply #7 on: September 30, 2006, 01:07:53 am »
yeah that'll work
Thanks a lot.  Well, the "-resolution 640x480" seems to work on the games that are "out of range" so far.  I've tested Popeye, MKII, Tapper, Punch-Out!!, Super Punch-Out!! and a couple others.  However, is there any reason why these games feel like they are running a little faster than what I'm used to?  Maybe I'm going crazy because it's so late, I'm having a party tomorrow and I wanted this thing to be playable...
Do you have a recommended resolution that I should try?
« Reply #8 on: October 01, 2006, 06:16:46 pm »
Do you have "throttle" turned on?  Because you should.
« Reply #9 on: October 02, 2006, 07:45:02 am »
I tried toggling the throttle on and off (F10) and I definitely have it set at the slower speed.  I guess Punch-Out!! in the arcade is a lot faster than it was on the SNES like I remember it...
