Author Topic: volume help  (Read 2343 times)
smythe
  • Last login:June 13, 2010, 04:28:06 pm
volume help
« on: September 28, 2006, 10:40:53 am »
hi ive a jamma loom in a cab
i have one volume button this has 3 contacts how do i hook my speakers up to this?
i have four wires from my speakers
cheers smythe
Re: volume help
« Reply #1 on: September 28, 2006, 10:49:13 am »
Volume button doesn't wire directly to the speakers.  It wires to whatever is producing the audio.
Volume pot would have three contacts - max, min, and ground.
Speakers each have two.  In and out.
smythe
Re: volume help
« Reply #2 on: September 28, 2006, 02:46:25 pm »
hi help me out here
we have speaker +&- from jamma
& 2 speakers with 2 wires from each..
how do i wire these to the pot?
cheers in advance smythe
Stingray
Re: volume help
« Reply #3 on: September 28, 2006, 04:25:02 pm »
http://www.pachislo.com/pachislo/parts_detail/volume.html
Top item on the page 5 for $15. These are inline volume pots that are made for pachinko/ pachislo machines, but I don't see why they wouldn't also work in an arcade cab. The only problem is that you have one pot for each speaker, so you have to set your left & right volumes independantly.
-S
Q*Bert_OP
  • Oh yes, we did!
Re: volume help
« Reply #4 on: September 28, 2006, 04:25:58 pm »
-S
Might not work...different resistance lavels...
Re: volume help
« Reply #5 on: September 28, 2006, 04:28:27 pm »
It would work... it's just a resistor.  It would probably not work the way he wants it to, though.
2600
Re: volume help
« Reply #6 on: September 28, 2006, 04:41:44 pm »
Looks like it is wired wrong so don't buy it.  You don't want a resistor.
Search for the link to oscarcontrols site on basically how to do it.  Do another search from Peale as he asked this question about a year or two ago.
diverdown
  • Last login:April 21, 2025, 03:45:48 am
Re: volume help
« Reply #7 on: September 28, 2006, 07:53:13 pm »
If the volume control looks anything like the second picture on the above linked page
Mind you it doesn't look like it is wires right in the pic
Then you have in out and ground
So if u have two speakers join the two + wires of the input together and the two + wires of the output together and all the -ve wires together
Now you have three wires  in out and ground
But without a pic i am guessing
If it ain't broke give it to me...i'll soon fix that
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
Re: volume help
« Reply #8 on: September 28, 2006, 08:42:58 pm »
Wow...good memory!
http://forum.arcadecontrols.com/index.php?topic=43512.0
Spaz Monkey
  • Last login:February 15, 2011, 11:33:55 pm
  • Hit me with a chicken quesadilla and a Coke.
Re: volume help
« Reply #9 on: September 30, 2006, 01:57:32 am »
So would it be something like this:  from the harness, speaker+ as input, and from the volume control to the speaker, the speaker+ wire?
