Author Topic: arcade power supply marquee help  (Read 1527 times)
smythe
  • Last login:June 13, 2010, 04:28:06 pm
« on: September 27, 2006, 12:10:40 pm »
i had an empty hang-on cab that had been stipped of everything apart from the monitor...
i purhased a jamma loom & power supply from e-bay ...
i added a control panel ect ect everything is working ok....
but im unsure how to hook up the marquee light where do i get the power from the main power? the switch mode supply?
cheers smythe
grantspain
Re: arcade power supply marquee help
« Reply #1 on: September 27, 2006, 12:20:28 pm »
take it from the psu mains input
fredster
  • Grand Prophet of Arcadeology
  • Last login:February 16, 2019, 04:28:53 pm
  • It's all good!
« Reply #2 on: September 27, 2006, 02:16:42 pm »
You can take it from anywhere except the from the isolation transformer to the monitor.
Normally they have a fused lead from a bank of fuses just off the filter capacitor.
Wire it up by soldering off the main power cord's first connection is a good place. If it ever goes down you know it's getting power from the cord that way.
King of the Flying Monkeys from the Dark Side
