Author Topic: How do I configure my computer to display upsidedown?  (Read 1675 times)
« on: September 26, 2006, 10:09:12 pm »
I have a 3 sided cocktail table and I want the display to be rotated 180 degrees.  I do not have a graphics card so when I go to display properties -> settings -> advanced there is no rotate option...  Any ideas?
I'd also be open to a solution rotating Gamelauncher 180 degrees and then all of the horizontal games in MAME..
Thanks!!
  • Last login:Today at 01:32:52 pm
Re: How do I configure my computer to display upsidedown?
« Reply #1 on: September 26, 2006, 10:23:12 pm »
For a golbal solution.... buy a video card that does support rotation.
both gamelauncher and mame support rotation btw... doesn't help you with anything else though
« Reply #2 on: September 26, 2006, 10:33:28 pm »
Thanks.  So for a short term solution, how do I setup Gamelauncher to rotate 180 degrees and launch horizontal games in MAME 180 degrees too?
Thanks a lot.
loadman
    • MaLa
« Reply #3 on: September 26, 2006, 10:40:18 pm »
I have a cotail table and tried having windows rotated via good video cards and 3rd party software.
Worked great for windows
I gave up on the idea as a few mame games got 'upset' having something in the background rotate them rather than mame itself.
I found that the if you left windows alone and use a FE that rotates 'natively' (there are a few)  and use the options on mame to rotate the games the setup was much happier.
Obvioulsy I hide Windows so you don't notice its not rotated
« Reply #4 on: September 26, 2006, 11:05:06 pm »
Can I still use Gamelauncher?
Also, how do I rotate a game 180 degrees?  I know -ror and -rol rotate 90 degrees but I can't seem to find the command to rotate 180 degrees?  I also can -flipx and -flipy but not rotate 180!
Any help would be great.
loadman
    • MaLa
« Reply #5 on: September 26, 2006, 11:27:33 pm »
Sure if you are using DOS. If using windows XP you would get more benifits using Mala or Atomic etc..
Flip Both
flipx                   1
flipy                   1
« Last Edit: September 27, 2006, 12:03:07 am by loadman »
« Reply #6 on: September 26, 2006, 11:40:52 pm »
Sure if you are using DOS. I using windows XP you would get more benifits using Mala or Atomic etc..
Flip Both
flipx                   1
flipy                   1
Ahhh... flip both!  duh!  OK, it works!!
I am using XP but I want to keep it simple and I really like the look of Gamelauncher.  I know there is a Gamelauncher skin but for some reason the font doesn't look right on my laptop (but maybe it will on my arcade monitor?).  I guess I'll give it a shot tomorrow...
loadman
    • MaLa
« Reply #7 on: September 27, 2006, 12:02:01 am »
I used Gamelaucher for many years until I got a decent PC for my Cocktail mame table.
If you are referring to the MaLa Gamelauncher skin (that I am using too until Gamecreature finishes my custom one) make sure you have put the supplied font into the windows font directory. I also choose a similar 'click' sound to play when moving through the selections.
« Last Edit: September 27, 2006, 12:06:00 am by loadman »
« Reply #8 on: September 27, 2006, 09:34:48 am »
I thought I did but maybe I didn't... I'll have to check that out because that would explain a lot...
