Author Topic: Strange problem U64emu and Mamewah  (Read 2014 times)
AMDman13
  • Last login:April 08, 2023, 09:21:58 pm
  • This Cab is going to be the end of me!!
« on: September 24, 2006, 12:24:14 pm »
First off I know and realize that this emulator is no longer supported an is not accurate however, it is the only way I can currently play Killer Instinct on my weak 900mhz cab's computer.
I downloaded a wrapper from Lazarus entitled u64kit2.0 and I using U64emu 3.0.5. Following the instructions on mamewah-setup.co.uk I was able to get this working flawlessly on my desktop computer which is XP based OS.
I then (via network) copied all settings over to the cabinet which is 98SE running mamewah.
Here is the problem and on the cab. Mamewah will launch U64emu fine, but when exiting U64emu it will not close the program. It causes U64emu to just hang and I have to kill the operation by dragging the keyboard out of the cab and pressing the dreaded control alt delete.
I figure since all settings are the same that it has to be something to do with 98SE. Is there something I am missing? Here is my U64emu ini. If anyone can help that would be awesome! Thanks!
### U64emu.ini (mamewah v1.61) ###
emulator_title                            Ultra64
### List Generation Settings ###
rom_path                                  c:\Emulators\u64emu\hdimage
rom_extension                             img
dat_file
nms_file                                  c:\Emulators\u64emu\U64-launch2.nms
catver_ini_file
list_generation_method                    rom_folder
### Execution Settings ###
emulator_executable                       c:\Emulators\u64emu\U64-launch2.exe
commandline_format                        [name]{nodosbox}{safelaunch}
alt_commandline_format_1                  [name]
alt_commandline_format_2                  [name]
game_specific_config_path
### Artwork Locations ###
artwork_1_image_path                      c:\Emulators\u64emu\snap
artwork_2_image_path
artwork_3_image_path
artwork_4_image_path
artwork_5_image_path
artwork_6_image_path
artwork_7_image_path
artwork_8_image_path
artwork_9_image_path
artwork_10_image_path
movie_preview_path
movie_artwork_no                          1
### Screen-Saver Settings ###
enable_music_in_screensaver               1
saver_type                                slideshow
movie_path
movie_fullscreen                          1
quit_delay                                30
wrapper_executable
wrapper_commandline_format                [name]{nodosbox}{nosafelaunch}
scr_file
### External Application Settings ###
ipc_file_or_path
app_1_executable
app_1_commandline_format
app_2_executable
app_2_commandline_format
app_3_executable
app_3_commandline_format
auto_launch_apps
### Additional Settings ###
music_path
lcd_display_file_path
lcd_fe_text
### Settings used by MAMEWAH ###
current_list                              0
« Last Edit: September 24, 2006, 12:26:27 pm by marlborroman13 »
My old user name was marlborroman13, but I kicked the habit many years ago!
  • Last login:Yesterday at 07:46:44 pm
Re: Strange problem U64emu and Mamewah
« Reply #1 on: September 24, 2006, 08:18:39 pm »
Nope... it's pretty much a os thing.  Upgrade to xp and it'll work.  Sorry.  :(
AMDman13
« Reply #2 on: September 24, 2006, 11:33:21 pm »
Thanks for the update. It's a bummer, but at least I don't have to scratch my head over it any more.
I'll wait untill I upgrade the beast and then run KI through Mame.
For now I will just launch the program through mamewah and use the ol'trackball to select KI or KI2 and launch from there. Not the end of the world by any means. Thanks again!
« Reply #3 on: September 25, 2006, 12:31:47 pm »
You might try using a autohotkey script in conjunction with the wrapper, but ahk doesn't work well in 9X either.
AMDman13
« Reply #4 on: September 25, 2006, 10:50:59 pm »
Thanks for the tip Howard_Casto.
I'm not sure that would work either though. It loads the selected game through mamewah fine. It just freezes once I hit escape to exit.
