Author Topic: Transformer input/output questions  (Read 2481 times)
Spaz Monkey
  • Last login:February 15, 2011, 11:33:55 pm
  • Hit me with a chicken quesadilla and a Coke.
« on: September 23, 2006, 11:56:22 am »
Long story short: got the guts of a cab with everything disconnected.  Was able to match all the connections up except for the transformer.  I have a "Peter Chou" p/s that has three wires (black, white, green) sticking out.  I have my transformer that has two connections on top, and 5 on the bottom.  What connects where?  The connections for my monitor and the marquee lights are connected together.  If it matters the spade connectors for the 105v and 125v are bent down while the bottom 0v, 115v, and E are bent up or vertical.
                       0v                              115v 1Amp
                       0v    105v   115v   125v   E
NightGod
Re: Transformer input/output questions
« Reply #1 on: September 24, 2006, 01:35:32 am »
E would be Earth/Ground, I assume?
If so, it should be 0v-White, 115V-Black, E-Green.
grantspain
« Reply #2 on: September 24, 2006, 09:42:55 am »
sounds right to me(in the u.k we attach the white to live and the black to neutral but it don't matter)
Spaz Monkey
« Reply #3 on: September 24, 2006, 01:10:23 pm »
..then just match the same colors on top?
grantspain
« Reply #4 on: September 24, 2006, 01:16:50 pm »
how do you mean?
NightGod
« Reply #5 on: September 25, 2006, 05:24:15 am »
You mean for the marquee lights and the monitor? Yes. Usually only the monitor goes after the isolation filter (the marquee lights usually connect to the line filter), but if your cab has them already connected together, then stick with that.
Ken Layton
  • Guru
  • Technician
« Reply #6 on: September 25, 2006, 11:16:02 am »
                       0v                              115v 1Amp
                       0v    105v   115v   125v   E
The top terminals are 0v (neutral or white) and 115v (hot or black) isolated output to the monitor only.
The bottom termals are the input power to the transformer and you select the tap closest to your typical line voltage. 0v (white or neutral), 125v (hot or black), and E (green or frame ground) are typical USA power standards.
Spaz Monkey
« Reply #7 on: September 26, 2006, 05:22:19 pm »
Thanks for all the help!!!  I have everything working now!!!!!
