Author Topic: transport of a cab (I need the info by tomorrow)  (Read 2290 times)
Rudi
  • Last login:September 13, 2007, 09:39:27 pm
« on: September 22, 2006, 12:49:22 pm »
I just convinced my better half that I should go to an auction tomorrow for a bankrupt arcade.  I've got a Dodge Durango.
Can a standard, fully working cab be placed on its back for transport?  It should fit in the truck with the seats down, but I don't know if it would damage anything.
Any info would be helpful.
Rudi
shardian
  • Trade Count: (+23)
Re: transport of a cab (I need the info by tomorrow)
« Reply #1 on: September 22, 2006, 12:57:54 pm »
I hauled two on their backs down a bumpy, gravel road strapped down to a trailer with no problems whatsoever. Just remember to do a thorough check before and after transport. Make sure everything is secure before so nothing breaks, and make sure everything is secure after before plugging up power.
Lilwolf
« Reply #2 on: September 22, 2006, 01:08:40 pm »
when laying them down be careful.  Sometimes the monitors aren't actually screwed in.  Seen someone lean them over and the CRT flop out and shatter
Stingray
« Reply #3 on: September 22, 2006, 02:00:24 pm »
I drove one home on it's back in the back of an Explorer. With the seats down the hatch was just short of closing, so I had to tie it down.
As stated, make sure nothing inside is loose and check the bottom for tokens, coins, screws or other small metal objects that might find thier way onto a PCB during transport.
-S
postalp123
  • Last login:March 18, 2024, 09:07:50 pm
  • Retro-gamers don't just play, they reminisce.
« Reply #4 on: September 22, 2006, 02:25:05 pm »
One, yes, two.....depends on the wheel wells protruding on the inside of your rear-bed.
Another solution is to haul @$$ down to your local Ryder Truck Rental and get a 20 footer for around $30 all said and done.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #5 on: September 22, 2006, 02:29:20 pm »
Take a tape measure ... measure cabs before you bid ... sometimes they look smaller than they actually are.
Cheers
Working: Not Enough
Projects: Too Many
Progress: None
eccs19
  • Last login:April 20, 2021, 10:36:08 am
  • Just plugin away!
« Reply #6 on: September 22, 2006, 02:49:59 pm »
Cheers
Know that from experience?   ;D
Working - Mr. Do! - Neo Geo 4 Slot - Bartop Mame
Project(s) - Pacman
CheffoJeffo
« Reply #7 on: September 22, 2006, 03:03:43 pm »
Yeah ... bought one of those big Midway 4-player cabs for a friend and went to pick it up. Neither the seller nor I had security hex bits with us, so we couldn't pop the CP off and those cabs are deceptively deep ... wouldn't go into my minivan on its back. I got it in on an angle, but it wasn't as smooth as I had planned.
And then there was that big NAOMI showcase ... ended up having to get that delivered, then disassmbled it, moved it, reassembled it ... it is NEVER leaving my basement.
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:Yesterday at 03:18:34 pm
« Reply #8 on: September 22, 2006, 03:23:10 pm »
I don't care what orientation you're going to haul the cab in, SECURE THE MONITOR SECURE THE MONITOR SECURE THE MONITOR.  And examine everything else to make sure there aren't any loose parts. Circuit boards securely fastened in place? Bummer to have them wiggle loose in a bump and smack around during the ride, messing up the components.
Don't forget protecting the outside of the cab. A good wind-resistant tarp (or one you don't care about getting frayed) is useful. Plastic wrap to completely encase it is even better if you have it.
--- saint
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
Rudi
« Reply #9 on: September 22, 2006, 05:09:59 pm »
How can I add additional support for the monitor?
Do you mean bring 2x4s?
-Rudi
Texasmame
  • No, no. He's in charge here.
  • Last login:February 18, 2022, 05:28:39 pm
  • Ba, ba, boom!
« Reply #10 on: September 22, 2006, 07:21:27 pm »
-Rudi
You really shouldn't need anything but the hardware in the cab to secure the monitors.  THAT SAID, be sure to bring at least 8 or so assorted bolts, washers and nuts - if they're not in the cab, you may not be able to get them at the auction.
And, yes, one will fit fine.  Just transported a DJ Jr in my PT Cruiser with the rear seats removed and have done one in a Jeep Grand Cherokee - both smaller than the Durango.
Have fun and good luck!   :cheers:
Rudi
« Reply #11 on: September 23, 2006, 11:13:37 pm »
Well, I came, I saw, I bid and I walked away empty handed.  I walked in with a max $ amount, and none of the machines I wanted sold for less.  Oh well, maybe next time.  It was a good learning experience.
The highpoint was that my teenage two boys and I had a great day together.  From the important life point of view I didn't walk away empty handed.
Rudi
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #12 on: September 24, 2006, 07:38:32 am »
What no pictures?  We wanted to see what was there too!!!   :hissy:
Rudi
« Reply #13 on: September 25, 2006, 09:19:01 am »
To tell you the truth, there weren't many good machines.  There were 2 very nice uprights (Ms. Pac Man, Asteroids) in almost perfect condition.  The Terminator 2 needed new artwork and had wood chipped off, but was working 90%.  There were 5 showcase shooting games, of which only two had a good monitor, and one didn't even work at all.  The two good ones went for $600 and $800.
Well, of the 30 machines, only 12 were usable as is.  The others needed monitor repairs or other work.  The NJ shore, we don't have a beach we have a shore, has about 50% redemption machines now and the games are being pushed out.  The only real good buy was for a sit down cockpit game, a Sega I think, that went for $150.  It had hydrylics and everything with a very nice monitor.  But, it weighed a ton.  I would have taken it but it was too wide to put in the basement.
The bummer was that one guy, a distributor, bought all the nice games.  Quick to bid, quick to raise the price.  I bumped up against him twice and lost both times.  If he wasn't there I would have had a machine.
Like I said, live and learn...
Rudi
