Author Topic: mamewah-problem reading roms  (Read 2138 times)
bsellers100
  • Last login:June 19, 2018, 05:46:46 pm
« on: March 19, 2003, 11:30:29 pm »
I have no problem getting mamewah to see the roms in each directory, but on about 2/3 of the roms it lists the roms with either an IP or a PT in front of the rom name.  With this extra in there the emulator cannot run the game.  Any ideas on what is causing this?
bsellers100
Re:mamewah-problem reading roms
« Reply #1 on: March 21, 2003, 08:31:02 pm »
help!!!!!
Minwah
    • MAMEWAH
« Reply #2 on: March 22, 2003, 05:28:59 am »
What emulator are you using?
bsellers100
« Reply #3 on: March 23, 2003, 05:25:14 pm »
So far the ones giving me problems are Visual PInball and ZSNES.  The emulators themselves work fine, it is just that some of the roms are getting a prefix for some reason.
Distortion
  • Last login:June 10, 2016, 04:39:20 pm
  • Saints Row 2, Sucka
    • Volition
« Reply #4 on: March 23, 2003, 10:25:23 pm »
you have to put them in a dos-compatible format, i.e. i think 6 or 7 letters or less, no spaces, etc.
Game programmers do not play games for a living.  Would you say a mechanic drives cars for a living?
  • Last login:February 01, 2026, 01:32:52 pm
« Reply #5 on: March 24, 2003, 01:50:01 am »
i don't think that's his problem at all but in case it is, it's called 8.3 format (8 characters, 3 char extension)
so my document.doc= my_doc~1.doc
or something like that
Minwah
    • MAMEWAH
« Reply #6 on: March 24, 2003, 09:55:41 am »
Odd, sounds like a bug...could you mail me (minwah1959@hotmail.com) your ZSNES .LST file which will be in the MAMEWAH program directory?
Cave
  • Last login:June 07, 2009, 10:27:58 am
« Reply #7 on: March 24, 2003, 03:14:54 pm »
Spooky, I've just encountered the same problem, only my roms have the prefix CE in front of them. Everything was fine, all listed and working ok until i decided to delete some roms (about 60) and refresh the gamelist. This was in my cab so i repeated the same thing on my main computer and this didn't happen, luckily i could just copy the games&snap lists across to my cab.
btw This was using the Magic Engine emulator.
Minwah
    • MAMEWAH
« Reply #8 on: March 24, 2003, 05:43:32 pm »
Cave, do your 2 PC's run different versions of Windoze?
Cave
« Reply #9 on: March 25, 2003, 02:15:55 pm »
They are absolutley identicle even the cpu & mobo, both winXP, the same file structure , copied everything over to my cab the only difference is the drive letter, in my cab its C:
and on my main computer its F:   :-\
Minwah
    • MAMEWAH
« Reply #10 on: March 25, 2003, 05:34:22 pm »
How odd  :-\
It seems that using short filenames will fix the problem, or you can manually edit the LST file and remove the bits that shouldn't be there.  But you shouldn't have to...
It will be fixed next release if all goes well  :)
