Author Topic: Router bit questions.  (Read 3182 times)
sealslayer
  • Last login:March 18, 2014, 04:41:30 pm
  • Why screw when you can bolt
« on: September 14, 2006, 03:14:26 pm »
I need to get a bit to cut the groove out for the T-molding, the only ones that I've seen that look like they will do the job is biscuit cutting bits, are these the right ones or is 4mm to wide a gap?
My T molding is still in transit so I cant really tell until it arrives but I may have to order the bit in so I really need to know before hand.
Gambit
  • Last login:November 16, 2006, 09:40:19 am
    • The BlueSparks Network
Re: Router bit questions.
« Reply #1 on: September 14, 2006, 04:30:03 pm »
No those are not the correct bits.
You want slot cutters, such as the three here:
http://www.t-molding.com/cart/customer/home.php?cat=5
They are also easy to find at Home Depot, just do an online search for slot cutters.
NiteWalker
  • Last login:April 25, 2022, 07:33:24 pm
  • Routers can do anything.
    • SimpleCase Custom Arcade Stick Enclosures
« Reply #2 on: September 16, 2006, 01:53:42 am »
Here's what you need:
http://www.holbren.com/home.php?cat=192
You want the 1/16" cutter (first one on the page) and the 1/2" or 1/4" arbor to match. If your router accepts 1/2" bits go for the larger arbor size. It will give you a much smoother cut.
It's 9am. I'm calling it a nite.
sealslayer
« Reply #3 on: September 16, 2006, 05:06:00 am »
Thanks guys  ;D
