Author Topic: Hantarex 1v/5v switch?  (Read 2215 times)
scumball
  • Last login:September 24, 2019, 02:23:47 am
« on: September 10, 2006, 04:29:40 pm »
I read this on the Ultimarc website
"Hantarex (and many other) monitors are specc-ed to accept 1 volt or 5 volts (Hantarex have a switch"
Does anyone know where this switch is on a Hantarex Polo 25"?
grantspain
Re: Hantarex 1v/5v switch?
« Reply #1 on: September 10, 2006, 05:22:30 pm »
i have never seen a switch on a polo,maybe on a mtc 9000
Kevin Mullins
    • Me on Myspace
« Reply #2 on: September 10, 2006, 06:06:15 pm »
From the Polo manual:
VIDEO INPUT SIGNAL
RGB positive going with input impednace of 1k ohm. Sensitivty 1.5 - 4.0 V p.p.
SYNC INPUTS
Horizontal and vertical, positive and negative, composite or seperate with automatic selection. Input impedance 1k ohm. Input level 1.5 - 4.0 V p.p.
scumball
« Reply #3 on: September 11, 2006, 03:23:55 pm »
So could my Xbox AV adaptor and JPAC be pushing the level up too high if that states 5v and the monitor is 1.5v to 4v.
I am trying to get to the bottom of why my picture using this has 'herringbone' wavy lines throughout yet with a Jamma board and PC with AVGA it is okay.
Any ideas?
grantspain
« Reply #4 on: September 11, 2006, 04:32:17 pm »
can you post a picture,its possible that signal input is so high that its creating flyback lines otherwise it could be some sort of ground fault
scumball
« Reply #5 on: September 12, 2006, 06:15:22 am »
It's hard to get a picture as it's quite slight.  It seems like a ground fault as it is ever so slightly wavy with herringbone effect on whites/bright areas.
The Xbox only has a two pin power lead so no ground there.  It is meant to be grounded through the JPAC but that doesn't seem to be working.
I thought it may be the monitor frame ground, as my Hantarex UPS250 supply doesn't have a FG connector for the monitor, but if the PC with AVGA looks okay and so does the single Jamma board I have, I guess that rules that out.
Any ideas?  Can I ground an Xbox?  Would powering the Xbox from a different socket make a difference?  (I'm UK based)
grantspain
« Reply #6 on: September 12, 2006, 12:29:06 pm »
i think its probably the xbox vga convertor,its certainly not a fault with the monitor-perhaps it may be the quality of the signal lead
scumball
« Reply #7 on: September 12, 2006, 05:30:44 pm »
Not using a VGA convertor - am using an Ultimarc XBox AV adaptor which outputs 15KHz RGB to a D15 connector.
grantspain
« Reply #8 on: September 12, 2006, 05:45:13 pm »
best to contact ultimarc maybe they know whats going on,but whatever it is its either some sort of ground problem or some sort of interference problem-whenever i have encountered these sort of problems its always been down to ground or the cable itself-maybe the cable needs a shield
