Author Topic: CPV2?  (Read 2795 times)
Svaroh
  • Last login:May 21, 2007, 01:44:32 pm
CPV2?
« on: September 08, 2006, 04:58:14 am »
hi all,
so at 2am i decided i should put CPV2 on my cabinet. i cant make it work. as evidenced by me posting here.
im running Mamewah 1.61 as a frontend, Mame 0.53 due to the 400Mhz box in my cab with win98.  i got some 'bad command or file name' stuff when i ran the batch file to install the system stuff CPV2 needs. and i kept getting an error while trying to make a layout with a photo of my CP, the pic was 640x480, same as my monitor, so i made the .lay file on my PC and just transfered it over. hopefully that'll work.
im hoping Jcrouse will stumble over this post, or someone else who i knowledgble about such things.
thanks in advance
-J
jcrouse
  • Last login:January 09, 2010, 05:53:51 pm
    • CPViewer
Re: CPV2?
« Reply #1 on: September 08, 2006, 06:59:56 am »
The program has not been tested on Windows 98. Unfortunately I don't have anymore 9x boxes around to give it a try. Tell me more about the error. Is it happening when you run the batch file to install the system files? EXACTLY, what is it saying?
John
jcrouse
    • CPViewer
Re: CPV2?
« Reply #2 on: September 08, 2006, 12:14:13 pm »
OK, I loaded up a 98 box just for you and did some testing. Open up the batch file included with the system files and change the entried regsvr32.exe to rundll32.exe and try it.
John
Svaroh
Re: CPV2?
« Reply #3 on: September 08, 2006, 01:16:57 pm »
Mr Cabinet liked that a lot better. no errors on the system files.
now when im trying to make my mame.dat file in the dosbox i get this error...
i typed     d:\mame> mame -listxml|xml2info> d:\mame\mame.dat
and it says...
error: unknown option -listxml
error while parsing cmdline
i also tried:        d:\mame> mame.exe -listxml|xml2info> d:\mame\mame.dat
                       d:\mame> mame -listxml|xml2info > d:\mame\mame.dat
                       d:\mame> mame.exe -listxml|xml2info > d:\mame\mame.dat
same result.
oddly enough, before the system files were installed i did this step with no trouble, mind you the mame.dat file was blank, but it at least made one for me
thanks for your speedy help btw
-J
ps, i am using your cpv2 manual as a guide, im just special and get errors at every step :P
« Last Edit: September 08, 2006, 01:27:41 pm by Svaroh »
jcrouse
    • CPViewer
Re: CPV2?
« Reply #4 on: September 08, 2006, 01:38:26 pm »
Well, there appears to be more issues with 9x systems. Even though you didn't receive any errors the system files are not registered correctly, at least on my system. I will take me some time to debug, If I even do. I am sorry to say that I may not support Win 9x, at least for now. I am busy adding new features to CPV2.
Sorry,
John
Svaroh
Re: CPV2?
« Reply #5 on: September 08, 2006, 01:45:37 pm »
argh.
Thanks for your help, going so far as do dredge up an old 9x box to do tests.  if an answer comes to you late one night, feel free to pm me :P
again, thanks.
-J
jcrouse
    • CPViewer
Re: CPV2?
« Reply #6 on: September 08, 2006, 01:48:18 pm »
Nah, no dredging involved. I actually did a reload of a WInXP system and put 98 on it. Almost made me cry. :laugh2: Anyways, now I have it for testing.
John
um3k
  • Last login:Today at 09:22:33 am
Re: CPV2?
« Reply #7 on: September 08, 2006, 06:54:48 pm »
and it says...
same result.
The Mame version you said you were using (0.53), did not have the listxml command line switch... try using:
d:\mame> mame -listinfo > d:\mame\mame.dat
Svaroh
Re: CPV2?
« Reply #8 on: September 08, 2006, 11:55:19 pm »
though im probably flogging a dead horse, i gave your idea a try um3k, it generated a mame.dat file great, (way to go um3k, thanks) even had loads of stuff in it, the File Setup Utility was able to create the files it needed to with no problems, i even got to successfully try the first example from the manual, the mamewah.jpg one, worked great. thing is when i try something like
C:\cpv2> cpv2.exe -r=dkong
i get an error box that says
Runtime Error '380'
Invalid Property Value
this may be what you were talking about Jcrouse, i dont know but on the off chance that my compy did something yours didnt, or vice versa, im hoping this is a simple issue.
if not, then damn my persistance.
and thanks
jcrouse
    • CPViewer
Re: CPV2?
« Reply #9 on: September 09, 2006, 07:01:38 am »
Exact same issue. I will look into this but it will be a couple of weeks.
John
jcrouse
    • CPViewer
Re: CPV2?
« Reply #10 on: September 12, 2006, 08:28:45 am »
OK, just an FYI ..... This is being worked on now. There will probably be a new Systems Files for 9x package in the next few days (I hope).
John
jcrouse
    • CPViewer
Re: CPV2?
« Reply #11 on: September 15, 2006, 09:26:44 pm »
OK, it is now tested and working on Windows 98. Download the latest CPV2 System Files pack from my website and run setup.bat. Let me know how it works. Feel free to email me directly at the address on my website.
John
