Author Topic: mala praise!!!  (Read 6949 times)
squire
  • Last login:May 06, 2014, 12:31:17 pm
mala praise!!!
« on: September 05, 2006, 01:36:07 pm »
well after hours and hours of trial and error i finally got mala working :) :)
im so feaking happy!
here a screen shot of the layout i made..
also im having a bit of promblem with the start up video it seems to be running really slow and laging is there any tricks or advice to speed it up a bit ???
thanks all for the help...
« Last Edit: September 05, 2006, 01:40:26 pm by squire »
gamecreature
  • Last login:October 29, 2008, 08:35:37 pm
  • I'm making this up as I go along.
    • Gamecreature
Re: mala praise!!!
« Reply #1 on: September 05, 2006, 03:51:59 pm »
Looks very good, Squire.
How does the video play when it's not running in Mala? If the video plays well, then check for anything else that might be trying to run at the same time (sounds, etc.)
Make your cabinet look its best with custom art from
Gamecreature!
squire
Re: mala praise!!!
« Reply #2 on: September 05, 2006, 04:23:48 pm »
the video runs well,but runs slow in the mala start up?
that what im confused about,what would be the best format to use also..
thanks
loadman
  • Moderator
    • MaLa
Re: mala praise!!!
« Reply #3 on: September 05, 2006, 07:00:10 pm »
Nice Work!!!
Consider uploading it to MaLa Website
 8)
philby85
  • Last login:August 28, 2008, 08:25:17 pm
Re: mala praise!!!
« Reply #4 on: September 05, 2006, 11:54:44 pm »
I second that recommendation! Nice work.
philby
BamBam
  • Last login:November 03, 2011, 07:18:19 am
  • This is better than Disney Land man!
Re: mala praise!!!
« Reply #5 on: September 08, 2006, 08:05:04 pm »
I third that vote.  Can you tint it blue? ;)
John
Galaga... Was there any other game?
Re: mala praise!!!
« Reply #6 on: September 08, 2006, 10:58:29 pm »
Very impressive!
I've just started toying with it. I notice a reference to jukebox in the files.
Does mala have a built in jukebox?? I cant find it if it does.
loadman
  • Moderator
    • MaLa
Re: mala praise!!!
« Reply #7 on: September 08, 2006, 11:49:35 pm »
Very impressive!
Indeed it does (see attached pic)
Re: mala praise!!!
« Reply #8 on: September 09, 2006, 09:49:20 am »
Ok, I know I'm looking like an idoiot here, but I cant find the options screen you posted.
How, pray tell, do I get to that screen?
Thanks.
swindus
  • Last login:July 28, 2021, 05:52:50 am
    • MaLa - M.A.M.E. Launcher
Re: mala praise!!!
« Reply #9 on: September 09, 2006, 11:36:23 am »
Re: mala praise!!!
« Reply #10 on: September 09, 2006, 02:31:50 pm »
Im trying to sort all this out, and the link helps a lot..
