Author Topic: Will Cap Kit fix pincushioning on a PC monitor?  (Read 1331 times)
hickster
  • Last login:April 19, 2015, 08:12:57 pm
« on: August 30, 2006, 08:53:29 am »
Hi all,
I'm currently working on converting an old Bubbles machine into a MAME cabinet and all I have to use is a 17" CRT. I really don't want to spend money on a huge monitor at this point - maybe later. Anyway, a while back I noticed my neighbour had placed an old monitor out with his trash. I quickly grabbed it and brought it home. It's a Hitachi CM2085MU 20" CRT, it would be a great solution for my MAME cab. The only real problem with it is some severe pincushioning. I tried taking the monitor apart and adjusting the trimpots with no luck (there were pots labelled pincush/ vert/ horiz etc). I'm new to all this and I've been reading a lot about cap kits. Would a cap kit solve my problem in this case?
Thanks in advance,
Cheers
Ken Layton
  • Guru
  • Technician
Re: Will Cap Kit fix pincushioning on a PC monitor?
« Reply #1 on: August 30, 2006, 10:43:18 am »
Most computer monitors have programmable pincushion adjustment in a setup menu. However if that doesn't work there's a couple of posibilities:
It needs a capkit
The pincushion correction transistor is bad.
SirPeale
  • Green Mountain Man
« Reply #2 on: August 30, 2006, 09:21:27 pm »
Conveting a Bubbles machine to Mame?  Oh man...you're in for it now...
