Author Topic: Ported sub in mini-galaga  (Read 2509 times)
crashwg
« on: August 29, 2006, 06:23:37 pm »
The facts:
1. I've got a set of Creative I-Trigue 3300 speakers which includes a ported sub.
2. My cab is on casters which creates about a 1/2" gap around the bottom
3. The cab is approximately 2'x2'x4.5' (for area purposes if they are needed)
My plan:
I was thinking that I'd cut a ~8" hole in the bottom of the cab and aiming the sub out of it
The questions:
Will enclosing the sub in the arcade machine affect the purpose of the port?
Will the sub, being ported, affect the arcade machine in an undesirable manner?
I was thinking that if it is going to be a problem that I could cut a port-sized hole in the back of the cab and place the sub in a way that the holes would line up but I don't want to do that if I don't have to, hence this post...
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
jukie
  • Last login:December 21, 2006, 04:12:18 am
Re: Ported sub in mini-galaga
« Reply #1 on: August 31, 2006, 01:57:10 am »
Yeah, Ive got the same worry with my jukebox, thou my sub is a 10" Logitech THX Certified 200w,  Ive curently no back on the jukebox at the moment because of this reason. Any help ?
BobA
  • What Me Worry?
« Reply #2 on: August 31, 2006, 09:18:24 am »
Article on putting subs in cabinets.
http://www.audioholics.com/techtips/setup/loudspeakers/subwooferplacement01.php
I have a ported sub in the bottom of a cab.  I found that I needed a large opening for it to sound right.  This was done by putting speaker cloth over a large square cut in the door. If your woofer is pointed down you will loose some of its effectiveness if the port cannot fire into free air as well.  If the port is enclosed you will muffle some of the sound from your subwoofer.
