Author Topic: Still cant get this one figured out (lightgun)  (Read 2261 times)
bsgamble
  • Last login:October 27, 2006, 07:46:58 pm
« on: August 29, 2006, 10:13:03 am »
Im using ArcadeVGA to an arcade monitor.  Both the Guncon2 and HID Compliant drivers are installed and when i disconnect the gun from USB that goes away so im assuming the driver is correct and that the computer is recognizing the gun as it should, however I still cant get any action to occur using the gun.  What could i be doing wrong?
