Author Topic: Problem with custom arcade stick  (Read 1852 times)
esvedebe
  • Last login:September 01, 2006, 10:28:33 pm
« on: August 23, 2006, 11:07:35 am »
Hello,
This year's summervacation I finally started with my custom aracde controller. Using Suzo buttons and stick and a Logic3 gamepad (http://www.game247.nl/Scripts/prodView.asp?idproduct=16602) to hack (10 buttons and a single ground) I started the whole project.
The soldering went fine, even though is was my first time. I daisy chained the ground. All the buttons were connected, I was ready to go. I checked everything in the control panel and it looked and worked fine.
BUT... when I played Street Fighter for about a minute the controls became unresponsive. In the control panel the gamepad/custom stick was not recognised. I unplugged the USB wire, plugged it in again AND... it was working again. I can leave the stick connected for a day or play Puzzle Fighter with no problems, but as soon as I play any game with a lot of movement and buttonpresses the gamepad will become unresponsive.
It's on my mind now for a couple of weeks and I don't know what to do now. Order another gamepad and start soldering again, use different wire, rewire the whole thing?
I didn't order any extra parts (lesson learned), so I don't like to order everything again. I'm now curious if anyone has experienced the same thing and does know what the problem is? I hope someone can help me with this.
My top 5:
1. Bad soldering
2. Bad groundwiring
3. Bad button/stick wiring
4. Bad microswitch
5. Burned the gamepad during soldering
PS
I could post some photo's of my not so great stick.
ahofle
    • Arcade Ambience Project
Re: Problem with custom arcade stick
« Reply #1 on: August 23, 2006, 11:11:26 am »
I've had similar problems when the USB bus isn't getting enough power.  The device just vanishes.  If you are using a USB hub, try plugging into the main USB inputs on the case and see if that helps.  Or try another input and see if that helps.
Kevin Mullins
    • Me on Myspace
« Reply #2 on: August 23, 2006, 11:17:50 am »
Or try a "powered" USB hub.
I've had several devices do something similar even plugged into the pc's main USB port.
Gamepads, MP3 players, webcams, etc.
Plugged them through a powered USB hub and all worked fine.
Doesn't sound like a problem with your workmanship since it does essentially work.
Probably just a USB issue.  (my $.02)
esvedebe
« Reply #3 on: August 23, 2006, 11:31:32 am »
Thanks for the reply, when I get home I'm gonna try that.
Stupid me, I used the USB port of my internal cardreader. Why didn't I try that sooner, I was about to start all over.
But thanks again.
esvedebe
« Reply #4 on: August 23, 2006, 02:49:46 pm »
Aargh, I just tried to connect it to my main USB port... Didn't work! Unplugged all other  USB devices still didn't work!
Well, all that's left is to buy a powered USB hub, I'll let you know.
ahofle
« Reply #5 on: August 23, 2006, 03:07:51 pm »
Good luck.  Please post back when you resolve it...others may later search for this same problem and find your solution.
Gambit
  • Last login:November 16, 2006, 09:40:19 am
    • The BlueSparks Network
« Reply #6 on: August 23, 2006, 11:41:57 pm »
Could be shorting one pin to ground.
After soldering, make sure none are touching or shorting together then use a hot glue gun to cover them.
esvedebe
« Reply #7 on: August 24, 2006, 04:49:44 pm »
Well, I tried the powered USB hub... it didn't work.  :hissy:
I checked the circuit board, it has one ground, I daisy chained it to all buttons and it is not touching any other pins. So how to check if it is shorting with a pin.
I do have a multi-meter (or how is it called), but I don't have I clue of how to use it. Is this thing able to check all my connections, if so how?
Does anybody have some tips or a website on how to use a multimeter on a soldered circuit board?
I do have the feeling that the microswitches of the stick have something to do with it. Everytime I use the stick intensively it crashes. So could the microswitches be faulty, or is that not possible?
I'm totally lost now, any help is appreciated
ahofle
« Reply #8 on: August 24, 2006, 05:14:09 pm »
It doesn't work at all?  Or it works and then vanishes after playing a few minutes like before?
esvedebe
« Reply #9 on: August 24, 2006, 05:28:41 pm »
It worked like it did before. It's recognised as a gamepad and I can play for a while until the action gets intensive, than it gets unresponsive.
It's still recognised by Windows in the control panel, but unresponsive, then I unplug and plug in it again and it works (for a while).
I
ahofle
« Reply #10 on: August 24, 2006, 05:35:52 pm »
Well I would say you've almost certainly ruled out bus power as a problem.  Sounds like it must be wiring as you suggest.
