Author Topic: Slot Depth?  (Read 3039 times)
NickC
  • Last login:January 10, 2010, 08:31:05 pm
  • Frosty!
    • Game On Webpage
Slot Depth?
« on: March 16, 2003, 02:26:06 pm »
How deep should a slot be to use t-molding?
IG-88
Re:Slot Depth?
« Reply #1 on: March 16, 2003, 03:20:41 pm »
I'm no expert but I would measure the length of the verticle part of the "T" and then cut the depth accordingly. Maybe make a few shallow cuts to begin with and test fit one end of the molding (in a out of site spot) to see that it sits down flush.
-HarumaN
Xphile
  • Last login:July 03, 2010, 12:54:48 am
  • I'll never go back to the NHL!
Re:Slot Depth?
« Reply #2 on: March 16, 2003, 07:01:49 pm »
I'm gonna make a wild guess at 3/8ths of an inch or a fraction deeper..:-)
Pull a year and a half strike- it's over 4eva..
besides, WHL rocks!
FractalWalk
  • Newbie
  • Last login:September 20, 2010, 06:12:37 pm
  • Life is time spent fighting entropy.
Re:Slot Depth?
« Reply #3 on: March 16, 2003, 07:03:29 pm »
I'm no expert either, but I don't think it really matters as long as it as at least the depth of the "T". I just cut mine about 5 mins ago using the bushing on the arbor bit as the limiter. It was deeper than I needed but everything fit just fine.
saint ganked my avatar.
radiator
  • Last login:April 18, 2013, 07:14:43 pm
  • SFA OK!
    • :: verticalcircle ::
Re:Slot Depth?
« Reply #4 on: March 16, 2003, 07:06:56 pm »
would it really matter if you acidently went deeper?
personally i wouldn't have thought so...
When the Germans bombed the British, the British ducked.
When the British bombed the Germans, the Germans ducked.
When the Americans started bombing, everyone ducked!
Jakobud
  • Last login:November 18, 2025, 02:28:46 am
Re:Slot Depth?
« Reply #5 on: March 16, 2003, 08:35:58 pm »
Haha.  No it won't matter if it's slightly deeper.
medley
  • Last login:November 27, 2006, 10:23:05 pm
Re:Slot Depth?
« Reply #6 on: March 17, 2003, 12:34:36 pm »
I'm ptretty sure that:
For 3/4" wide T-Molding the slot should be 3/32" wide and 5/16" deep.
For 5/8" wide T-Molding the slot should be 7/64" wide x 9/32" deep.
DeathMonk
  • Last login:April 03, 2015, 02:01:12 pm
    • MameStation.3
Re:Slot Depth?
« Reply #7 on: March 17, 2003, 12:41:29 pm »
The bit that I used went in 3/4"  :).. It still worked perfect.
Now with cup beer holders!
slug54
  • Last login:June 12, 2014, 09:00:21 pm
  • Man, I hope this cab fits through the door way!
    • Arcade Extreme
Re:Slot Depth?
« Reply #8 on: March 17, 2003, 05:37:22 pm »
The slot cutter I used had a berring that rides on the edge of the wood where the slot is being cut.There was no depth of cut adjustment it just does it. but if your using some other method to cut the slot ,just go a little deeper then the piece that goes in the slot.
                                Slug54
radiator
  • SFA OK!
Re:Slot Depth?
« Reply #9 on: March 17, 2003, 06:56:48 pm »
better to go a bit deeper than not deep enough (and then have to get the tools out and do it again!)
 :P
teacup
  • Last login:May 11, 2003, 08:44:29 am
  • Woot Wooot
    • Teacup Designs
Re:Slot Depth?
« Reply #10 on: March 17, 2003, 11:06:03 pm »
On a similar subject, how do you cut into the inner corners on the cab (the corner between the monitor and marquee)? Should you just do it as best you can, and then finish it by hand. Or is there some trick to it?
FractalWalk
  • Newbie
Re:Slot Depth?
« Reply #11 on: March 17, 2003, 11:20:35 pm »
If you are talking about the slot cut, it should be no different.
If you are talking about cutting out the side panels, then a router is the cleanest method. A jigsaw could work, but if you are cutting two panels simultaneously, it won't work well.
Cutting the panels one at a time will allow the jig saw to cut better but then your cuts won't be the same. Of course if shape it by filing and sanding and then cover it with T-molding, perhaps the difference won't be noticeable.
