Author Topic: AutoHotKey Escape?  (Read 8801 times)
MPTech
  • Last login:January 05, 2025, 03:58:54 pm
  • UltimateArcade completed!
AutoHotKey Escape?
« on: August 21, 2006, 11:53:31 am »
I'm at work, so I can't test it now, but is this close??
I'm using an X-Arcade CP and someone suggested mapping Player1 & Player2 (both pressed simultaneously) to the Escape.  I like this and would to set it up for anything I played via MameWAH, so AutoHotKey seemed like a great solution, rather than changing all of my .ini files.
I haven't used it before, but read the docs, so I wanted to see if I'm thinking correctly.
Is it this simple??
Num1 & Num2:: Esc    (or is it Escape?)
I did a couple searches on AutoHotKeys and found a couple others I'd also like to try.
Any other suggestions??
MPTech
   Better living thru technology!   ;-)
Re: AutoHotKey Escape?
« Reply #1 on: August 21, 2006, 04:52:34 pm »
No you want Numpad1 & Numpad2::Esc
But unless your layout is wierd, most people map start 1 and 2 to the keyboard numbers, not the numpad numbers, in which case it would be:
1 & 2::Esc
Now if you want it to act like an ipac in that it's a key shifted you want to use :
1 & 2 UP::Esc meaning that it doesn't fire escape unless 1 is held down, then 2 is pressed and released while 1 is still being held down.
Your ahk exe comes with a very extensive help file which describes various syntax.  You should look at it.
MPTech
« Reply #2 on: August 21, 2006, 07:57:38 pm »
Thanks again HC!
I think I want:  1 & 2 UP::Esc
I'll try it tonite when I get home.
MPTech
MPTech
« Reply #3 on: September 05, 2006, 12:58:11 am »
Thought I'd try this again, but stil not working.
I did review the help (looks like it could be a GREAT tool), but not being succesful on a simple task here.
I create a file called Esc.ahk (actually, I let the utility create it then renamed it).
I entered one line in the first blank line, as we discussed:
1 & 2 UP::Esc
I'm getting this message:
Error at line 11.
Line Text: Esc
Error: This line does not contain a recognized action.
The program will exit.
I thought it might not recognize "Esc" so I changed it to "Escape" and got the same message.
Any suggestions?
Thanks!   MPTech
MPTech
headkaze
  • 0x2b|~0x2b?
« Reply #4 on: September 07, 2006, 03:17:41 am »
I think the line your looking for is..
1 & 2 Up::Send {Esc}
According to the Key List escape key can be either Esc or Escape.
« Reply #5 on: September 07, 2006, 07:22:27 am »
Yeah, there's about 3 ways to do the same thing in ahk.  For some reason depending upon the syntax that is calling the function, sometimes you can't use some of them.
MPTech
« Reply #6 on: September 07, 2006, 03:19:28 pm »
Thanks for the help (again).
Makes sense, I'll try it tonite when I get home!
 :notworthy:
MPTech
