Author Topic: x arcade diy or psone controller hack?  (Read 1435 times)
muell67
  • Last login:May 23, 2021, 02:12:01 pm
« on: August 17, 2006, 10:31:41 pm »
Im building a arcade stick for use with my consoles, xbox, xbox 360, dreamcast and ps2. Im looking for opinions on wether I should go with the x arcade diy or a psone controller hack and adapters for the consoles. Im currently leaning to the x arcade because of future xbox 360 support.
I don't know if you know this but I'm sort of a big deal. I own many leather bound books and my apartment smells of rich mahogany.
Goz
  • KOTA
Re: x arcade diy or psone controller hack?
« Reply #1 on: August 18, 2006, 12:58:39 am »
Xarcades emulated ANALOG mode helps with gameplay as well. Just an extra perk. Sure its not pressure sensitive but still if a game requires you to play with the analog stick you can play them.
clanggedin
  • Last login:July 02, 2012, 11:08:55 pm
  • O'DOYLE RULES!!!
« Reply #2 on: August 18, 2006, 10:12:46 am »
I use a Pelican Real Arcade Jotsitck which has adapters for PS2, GC, and Xbox already built in. It also has a button you switch between digital and analog modes.
I would suggest replacing the joysticks and switches in you do get the real arcade stick.
