Author Topic: GGG Trackbal Booster Kit Sizes  (Read 1241 times)
Level42
« on: August 17, 2006, 01:55:42 am »
Can anybody who has the GGG Trackball Booster Kit tell me what the diameter of the wheel is and what the diameter of the shaft is ?
For anyone interested: I'd like to see if it's possible to use it on a 2.25" Suzo Trackball. The diameters I measured are 1.5" for the wheel and 1/4" for the shaft.
« Last Edit: August 17, 2006, 02:00:08 pm by Level42 »
Level42
Re: GGG Trackbal Booster Kit Sizes
« Reply #1 on: August 17, 2006, 05:11:19 pm »
Nobody ?? Randy ??
RandyT
  • Last login:Yesterday at 05:14:12 pm
    • GroovyGameGear.com
« Reply #2 on: August 17, 2006, 11:55:58 pm »
The diameter is about 1.46".  The center hole of the encoder wheel is clearanced for a #4-40 machine screw.  It is designed to bolt onto a stock encoder shaft.
RandyT
Level42
« Reply #3 on: August 18, 2006, 06:06:10 pm »
RandyT
OK, so that's different from the Suzo then, that wheel simply shifts over the shaft and that's it. So there's a small "tube" on the wheel to make this possible, I bet your wheels are totaly flat right ?
Don't think they will be useable on a Suzo then, at least not without some work...
« Last Edit: August 18, 2006, 06:11:32 pm by Level42 »
