November 20, 2025, 01:03:20 pm
Sorry my knowledge of acronyms is pretty bad. PS? Pin Set? Personal Software? Porcupine Shampoo? Any way we hacked one of these at work for the lunch room. Pretty straight forward. My friend did most of the hardware stuff and I helped a couple of guys with the software.The hardest part of putting the cable together was getting the jumper on (sorry don't remember which pins it was on) but other than that it was pretty straight forward. If the PS is pin set let me know, I think my friend can probably remember that.For Software we downloaded the software from BetaBrite and then got the BetaBrite API from the web. The version we used was in VB but I think there is an interface that uses Perl too.I am sure that doesn't help but please let me know if I can be of assistance.Jim
Okay so sometimes I am about as smart as a bowl of wet mice. Good thing is I can help you with this. I actually ordered the PS for ours. This is the website I used. http://www.alpha-american.com I'd like to tell you it was a pleasant experience but it was a little like pulling teeth. I did get what I needed and it works so I guess that is all that matters.
I just found some helpful information regarding manipulation of BetaBrites at www.i-hacked.com that should set you on the right path.
