Author Topic: 3 in 1 multi jamma board with remote control ...  (Read 9852 times)
arcadefever
  • Miami Beach Florida
« on: August 14, 2006, 05:56:29 pm »
i just got this, it's a 3in1 jamma board that allow you to play 3 jamma pcb in one cab. and the best is, to change between games you need to use a mini remote control  8)
the black wire that you see on the pcb, is the antena for the receiver.
it work perfectly, i tried last night.
anybody as see this before ?
the label on the remote and pcb say, "tnd 3in1 jamma"
i contact the seller, and he as no clue where this come from...
well it's mine now  :D
 :wink:
« Last Edit: August 14, 2006, 07:06:28 pm by arcadefever »
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: 3 in 1 multi jamma board with remote control ...
« Reply #1 on: August 14, 2006, 06:28:34 pm »
That looks pretty cool - congrats.
It looks like that powers one board at a time, which I am starting to think is a good idea, at least for some games (like 2 of the 3 I have in my MultiJamma cab!).
Let us know how it works out ... and if you can find any more.
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
danny_galaga
  • Last login:Yesterday at 06:40:20 am
    • dans cocktail lounge
« Reply #2 on: August 15, 2006, 09:31:34 am »
damn, thats a great idea! first i thought you meant it was a 3 in 1 game pcb! i mignt have to get a third pcb and make a cab for my lil collection (",)
Kevin Mullins
    • Me on Myspace
« Reply #3 on: August 15, 2006, 04:22:47 pm »
That kinda reminds me of those deals the bars used  to hide gambling type machines with a regular game in atrract mode.
They'd use the remote to switch back and forth from the counter if someone wanted to play the "forbidden" games.
Never saw one that had three slots though. (?)
I'm sure that's totally irrelevant to the one you have though.
Cool relay switching idea though !!
I posted on RGVAC to see if anyone there recognized it also.
shess
  • Last login:January 07, 2021, 04:17:28 pm
« Reply #4 on: August 15, 2006, 04:28:12 pm »
Hey, you got any closer pictures of that board?  I'm trying to build my own and the first design I had didn't work.  Thanks!
arcadefever
« Reply #5 on: August 15, 2006, 04:35:23 pm »
that true, usually they're 2in1. one of the game is forbidden game, i meet few people here in miami  used that on video poker machine.
arcadefever
« Reply #6 on: August 15, 2006, 04:35:57 pm »
i will as soon as i get home  ;)
monkeybomb
  • PM me to find out how to get a custom title like mine!
  • Last login:January 03, 2018, 07:16:29 pm
« Reply #7 on: August 15, 2006, 08:08:18 pm »
Also update if you figure out a maufacturer.  And what games are going in it?
arcadefever
« Reply #8 on: August 15, 2006, 08:17:57 pm »
any jamma game go in it, that pcb is made to play 3 jamma PCB in one cab.
monkeybomb
« Reply #9 on: August 15, 2006, 09:22:38 pm »
Yes but which 3 ones will YOU put in it.
arcadefever
« Reply #10 on: August 15, 2006, 10:16:43 pm »
oops  :P
well not sure now, probably in my 1943 cab...
will be 1943-1942-and contra  :laugh:
arcadefever
« Reply #11 on: August 17, 2006, 03:07:57 pm »
shardian
  • Trade Count: (+23)
« Reply #12 on: August 17, 2006, 03:24:22 pm »
So is this a custom job?
Kevin Mullins
    • Me on Myspace
« Reply #13 on: August 17, 2006, 03:52:52 pm »
Got the word over on rgvac from a fella that probably actually ordered and owned that particular one. He mentioned the blue jumper wire specifically. He says these came from somewhere out in Asia. (he never did specify the TND company) He also said the remote control portion could be programed to most any generic remote.
Apparently they are popular over there because of the whole forbidden gambling thing in some areas. So a couple of us were on the right track about them, but still not sure why they would have had three slots just for that particular application. But then again, from the looks of the layout, you could concievably have as many slots as you want.
Simple, yet very effective.
It'd be cool if you (arcadefever) could document each component for us to play around with building something similar. Doesn't seem like all that much to it. But I really like the relay switching idea.
MaximRecoil
« Reply #14 on: August 19, 2006, 10:20:50 am »
You are going to run into problems using that thing with multilayer boardsets, unless you make some extensions or something.
arcadefever
« Reply #15 on: August 19, 2006, 03:20:34 pm »
i made the jamma extensions already ....
arcadefever
« Reply #16 on: August 19, 2006, 03:22:24 pm »
kevin,
details picture will help ?
Kevin Mullins
    • Me on Myspace
« Reply #17 on: August 19, 2006, 05:54:55 pm »
Yes if you could......
At a minimum the relay information. I'm assuming all they are doing is relaying the power supply to each board. It looks like all those zener diodes are to keep things from feeding back into each board when the others are "on". Just a nifty little idea to play with even if it's not remote controlled. Just a simple push button controlled switcher similar to that would be cool.
There just seems to be very little as far as electronics on there. Couldn't be all that hard to duplicate something similar. (maybe not on a sweet pcb like that, but still)
CheffoJeffo
« Reply #18 on: August 19, 2006, 08:52:44 pm »
Someone here was working on a relay-based JAMMA switch board ... I can't seem to find the thread, though.
Cheers
Working: Not Enough
Projects: Too Many
Progress: None
Kevin Mullins
    • Me on Myspace
« Reply #19 on: August 20, 2006, 02:48:19 am »
I'll have to poke around for that thread then also.....
CheffoJeffo
« Reply #20 on: August 20, 2006, 06:54:01 am »
Found the thread ... my memory wasn't 100 accurate (he built one for is VS/PC cab),but ...
http://forum.arcadecontrols.com/index.php?topic=45208.0
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
