Author Topic: mk series games are choppy on mame32  (Read 1873 times)
ultravorx
  • Last login:May 09, 2007, 05:59:38 pm
« on: August 06, 2006, 09:23:02 pm »
Hey everyone, just starting out here with my mame project, but have a few questions.
Im in the process of building my cabinet, running gameex as a front end, and mame32 as the emulator. Quad stick is on order and im waiting for black friday to buy a 32" lcd monitor, my problem is this.
I have about 1500 roms, with the mk series being my favorite, on my main pc (3.8ghz p4, 4gb ram, 256 g force graphics card, raptor 10000 rpm HD, sb audigy 2 sound card) and my laptop (1.6ghz celeron with 1gb ram, factory sound) all roms play fine, but on my machine im building for my cabinet. I get horribly choppy sound on mk games.
the specs on the cabinet pc are:
1.8 p4, 512 ram, sound blaster card, radeon 256 9700 agp.
These a are bit better specs than my laptop, but the sound is so bad in umk3, its unplayable. Im running xp pro, stripped down, i have all the updated sound card drivers and windows drivers, but no matter what i do, i cant seem to get better sound.
I did try pulling a 2.8 ghz processor from another pc and the sound was much better, but i would probably would need a 3.0ghz to get it perfect.
So what am i doing wrong that a laptop is giving better performace than a desktop with more power!!!
Thanks,
Frank
kton25
  • Last login:November 02, 2024, 01:05:54 pm
  • Om Olommah!
Re: mk series games are choppy on mame32
« Reply #1 on: August 07, 2006, 10:54:51 am »
First, if you are using a front end, you shouldn't be using mame32.  Try regular ol' mame or possibly a mame build optimized for pentium cpus.
Second, are you using the same version of mame on all pcs?  Newer versions tend to run a bit slower.  Try an older version of mame on the cabinet pc.
With the specs you've listed for the cabinet pc, you shouldn't have a problem running the MK series.  I used to use a similarly spec'd pc for MK without slowdown or sound problems.  Again, it may just be that I was using an older version of mame.
ultravorx
« Reply #2 on: August 07, 2006, 10:48:50 pm »
all pc's are running the same version of mame32, and i did try the newest, and an older version on mame with no luck, still the same problem.  Its just a weird situation!!!
cdbrown
  • Bowowow
« Reply #3 on: August 08, 2006, 07:22:21 am »
They are all using the same default game settings for sound and video for all instances?
destructor
« Reply #4 on: August 08, 2006, 07:25:21 am »
1. Disable autoframeskip, set frameskip 0.
2. For newer MAME versions you should use better CPU
3. Use older MAME version.
