Author Topic: Help with AtomicFE  (Read 1460 times)
spun10th
  • Last login:October 02, 2006, 11:37:56 am
Help with AtomicFE
« on: August 04, 2006, 06:16:51 pm »
I'm trying out the Atomic front end and I really like it so, I just have a few problems.  I can't seem to get the page up/down function to work.  I have ran the key configurator and set the page up/down to left/right on the joystick, however, this does not seem to be taking effect.  It generates the atomicfe.key file but here's what's inside of it:
PLAYER1_BT1=65
PLAYER1_BT2=65
PLAYER1_BT3=65
PLAYER2_BT1=65
PLAYER2_BT2=65
PLAYER2_BT3=65
ESCAPE=65
DOWN=65
UP=65
RIGHT=39
LEFT=37
PLAYER2_START=37
PLAYER1_START=39
Can someone explain what the numbers are referring to (ie. whey do almost all buttons = 65?).
gonzobrian
  • Last login:April 18, 2011, 08:42:08 pm
  • This space for rent!
Re: Help with AtomicFE
« Reply #1 on: August 04, 2006, 07:05:22 pm »
Unless something has changes, left and right should page up and down out of the box.  Are you using a pnp module?  What happens after a clean install, before you run key config.  Now there is a new feature that pages a letter at a time but I have not used that yet.
youki
  • Atomic Front End Creator
    • Atomic Front End
« Reply #2 on: August 06, 2006, 06:05:45 am »
Hi,
How to you control Atomic ?  With a keyboard?  A Cabinet Joystick Via a JPAC or IPAC? A Keyborard Hack?  or a PC Joystick?
AtomicKey , for key configuration only works with 3 first option not with a PC Joystick.
The only way to change affectation of control with a PC Joystick is to use a tool like Joy2Keys  , that converts PC Joystick input to keyboard order.
Now, if you have a "keyboard" kind of input.  AtomicKeys should work withtout problems.
You run it, press start , then the tool prompt you for  "action" and you just have to press the key you want map to this action.
the code you see in the file , are windows key code.
