Author Topic: Advmenu issue!!!! Video mode problem!!  (Read 1524 times)
Elastikman
  • Last login:September 01, 2006, 10:35:34 am
« on: August 01, 2006, 02:31:14 pm »
Hello!
I using a TV, using the vga to scart cable!
The advmame is already setup, is displaying a nice picture!
Now i try to config advmenu...i can configure in advmenuc.exe the video mode and i save it, all fine here!
When i go run the advmenu.exe it gives this msg
"No video modes avaivable for your current configuration"
I already try to copy the correct values from advmame.rc to advmenu.rc
device_video_clock 5-100 / 15.73 / 60
device_video_format 15730 0.761905 0.047619 0.047619 0.142857 0.858779 0.0343511 0.00763359 0.0992366
But same msg appears...:|
I dont see any device_video_modeline (...) in advmame.rc to be put in advmenu.rc , do i need some?
What i need to do???
« Last Edit: August 01, 2006, 04:13:56 pm by Elastikman »
Elastikman
Re: Advmenu issue!!!! Video mode problem!!
« Reply #1 on: August 01, 2006, 07:35:07 pm »
I found the solution..
I was not press "Space" to select the correct resolution in advv...
 :laugh2:
