Author Topic: Ultimarc Tri-Sync Utility for use on TV  (Read 1056 times)
lettuce
  • Make It So!
« on: August 01, 2006, 12:48:08 pm »
Can i use the Tri-Sync Utility on my Toshiba TV, as im not to sure what Khz TV's can safely go up to? Using the Tri-Sync Utility it allows the AVGA card to display 31khz non-interlaced picture, just woundered if this would sort out a display problem i seem to be getting with my TV, where the picture will shake/flicker by very small amounts
