Author Topic: Wells-Gardiner 25k7194 - Jumpy Problem  (Read 1561 times)
shepP
  • Last login:November 18, 2006, 09:12:25 pm
« on: August 01, 2006, 08:56:58 am »
Hi,
I have a Wells-Gardiner 25k7194 hooked up to a j-pac and arcadevga.  I'm using a resolution of 640x288 in both windows and mamewah.  For some reason, no matter how much I mess with the vertical hold, I can't get it to be pefect.  The text and images on the screen always seem to move up and down the slightest amount.  No matter how much I play with the v-hold the screen always seems a tad "jumpy"
Any Suggestions?
Thanks,
shepP
Ken Layton
  • Guru
  • Technician
Re: Wells-Gardiner 25k7194 - Jumpy Problem
« Reply #1 on: August 01, 2006, 09:57:46 am »
Does it do this with a genuine arcade game board connected to it? If not then the monitor is not at fault.
shepP
« Reply #2 on: August 01, 2006, 11:14:31 am »
I don't remember it doing so with the genuine arcade monitor, however I'll plug the midway open ice board back in today to give that a test.  Thanks for info :)
shepP
shepP
« Reply #3 on: August 01, 2006, 03:00:23 pm »
I hooked up the arcade board and it does appear as though the problem still exists.  I guess I never noticed it before.  Any further suggestions as to what might be wrong?
Thanks,
shepP
Ken Layton
  • Guru
  • Technician
« Reply #4 on: August 01, 2006, 05:59:48 pm »
You did adjust the horiz hold and vert hold? You did confirm that the sync wires are plugged into the correct pins on the monitor board?
