Author Topic: recommend me some bondo!!!  (Read 4012 times)
squire
  • Last login:May 06, 2014, 12:31:17 pm
« on: July 31, 2006, 12:32:15 am »
well yeah im in need of some any recommends?
nostrebor
  • Not enough wit to effectively use this space...
  • Last login:October 04, 2013, 02:02:41 pm
  • SHOCKING!!
Re: recommend me some bondo!!!
« Reply #1 on: July 31, 2006, 08:25:50 am »
Go to your local Wal-Mart, walk to the automotive section, and pick up the can marked "Bondo".  ;) ;D
What? Choices?? Well, yes there are several choices...
You want the one that is *not* fiberglass, metal impregnated, or fancy dandy. Just regular plastic filler Bondo. It'll be the cheapest one, more than likely. see the pic attached...
97thruhiker
  • Last login:October 04, 2014, 01:55:30 pm
« Reply #2 on: July 31, 2006, 11:01:55 pm »
Just finished a cabinet restoration where I used standard bondo to patch some holes and rebuild some corners.  Great stuff, highly recommend it.  Its very easy to work with except for the fact that it dries very quickly so mix it in small batches.
NightGod
« Reply #3 on: August 01, 2006, 01:21:23 am »
If you are only doing some small wood repairs/filling holes, there's this stuff called Plastic Wood that's pretty amazing, as well. You can pick it up at all of the usual places.
dweebs0r
  • Ascendo tuum!
« Reply #4 on: August 01, 2006, 08:29:02 am »
What about areas that include t-molding slots?
If you bondo up the are can you still cut a groove for the t-mold? or do you have to trim the t-molding and put it in place without the slot?
Thanks,
-D
shardian
« Reply #5 on: August 01, 2006, 08:40:34 am »
How big of a t-molding strip are you talking about? If it is a small area, use a dremel tool to clean out the t-molding slot in the bondo.
dweebs0r
  • Ascendo tuum!
« Reply #6 on: August 01, 2006, 08:42:49 am »
I'm talking about five or six inches of an area where a chunk on the cab is missing.
Almost as if someone stuck a screwdriver in the t-molding slot and then broke off a big piece.
-D
97thruhiker
« Reply #7 on: August 01, 2006, 12:34:25 pm »
What I would try (haven't attempted this but it could work) is to find yourself a thin piece of wood or heavy card stock the same width of your exisisting T-Molding slot.  Cover the edge that will be going into the slot / where the bondo is going with saran (plastic) wrap and clamp it in place.  Put your bondo on and square it off the best you can freehand with your exsiting sided where its not damaged (its okay to go with a little more so you can sand it out).  After the bondo hardens pull the card stock or whatever you use out.  If the saran (plastic) sticks within the grove it should not present a problem when laying the t-molding.  Sand it out to match the cabinets original line.  Repeat as neccessary.  The only question is the effect the bondo will have on the plastic wrap (will it eat through it or not, I guess you can always test a glob of bondo on some plastic wrap before beginning).
nostrebor
  • SHOCKING!!
« Reply #8 on: August 01, 2006, 01:15:38 pm »
If you have a router and a slot cutter, just bondo the whole area, shape the bondo to match the profile of the plywood, and then cut the groove in the bondo with your router. Bondo will cut and shape very similar to wood.
If you don't have a router, I would fill and shape like above, and then carefully cut the groove with a hacksaw blade or other cutting tool.
NOTE: Bondo is not very strong in tensile. If you make a tight T-mold groove in it, and hammer in a T-mold like a wedge in the groove, the bondo will split off. Make the groove wide enough that the t-mold will *bite* but not put a bunch of outer pressure on the bondo.
Personally, I would try to patch the spot with wood, but it is more "tool intensive".
Xphile
  • Last login:July 03, 2010, 12:54:48 am
  • I'll never go back to the NHL!
« Reply #9 on: August 04, 2006, 09:24:46 pm »
He's right, Bondo (it's a brand name, so I'm talking about any lightweight  2 part polyester filler) is a great product that works just like wood...
actually, found this somewhere, it's worth the read:
Auto Body Filler - Bondo
      Polyester auto body filler, usually referred to as bondo, is a modelmaking tool of great versatility. Bondo is intended to be used as auto body filler, that is, to fill either holes or depressions in auto body panels in order to bring the surface back to the original shape after an accident or it has rusted out. Because of its intended purpose it was formulated to be very tough and flexible, to bond very strongly to properly prepared surfaces, to be sanded or formed relatively easily, to hold a good surface finish, and to take paint very well, yielding a potentially beautiful finish. Bondo is readily available, inexpensive, and easy to use with a little experience.
      There are many different brands of auto body filler on the market and some are better than others. I have had good luck with Bondo brand and Bond Tite brand (sold at Scherba
Pull a year and a half strike- it's over 4eva..
besides, WHL rocks!
