Author Topic: Compiling Mame32  (Read 1029 times)
headkaze
  • 0x2b|~0x2b?
Compiling Mame32
« on: July 30, 2006, 07:29:41 am »
I'm used to compiling Mame32FX which has batch files you just run for each optimized build. Now that development on the Mame32FX has ceased, I need to compile the standard Mame32.
So I have MinGW environment set up, and I copy the original Mame into a directory, then copy the Mame32 files over the top. This is where I'm confused, after that I run the standard mingw32-make.exe and it compiles the command line version (mame.exe). How do I tell make to compile Mame32, I can't seem to find a Mame32.mak file anywhere. Can someone point out what I'm doing wrong here. Obviously it's something simple.
lokki
  • Last login:May 05, 2025, 06:18:51 pm
Re: Compiling Mame32
« Reply #1 on: July 30, 2006, 12:45:17 pm »
Check out
http://www.mameworld.net/mrdo/compile.html
to build the GUI you use the command
mingw32-make WINUI=1
headkaze
  • 0x2b|~0x2b?
« Reply #2 on: July 30, 2006, 11:25:35 pm »
Thanks for that. I had to add NAME=MAME32 aswell.
