Author Topic: Screenshots do not appear.  (Read 2493 times)
hartdre
  • Last login:September 19, 2006, 11:13:52 pm
    • NewGame Arcade
« on: July 25, 2006, 01:44:07 pm »
Hey.I have yet another problem.  :banghead:This should be the last (hopefully). When I run MameWah I cannot get the screenshots to appear. They did at one point but they do not now. I have verifyed all the paths. I am running Mame Plus! and the screenshots display in its GUI. Can someone help me?
Thanks alot,
Drew
(or is it?)
MKChamp
  • Last login:December 24, 2025, 01:30:45 pm
  • Stil around.
Re: Screenshots do not appear.
« Reply #1 on: July 25, 2006, 03:20:56 pm »
Can you post your mame.ini from mamewah?
hartdre
    • NewGame Arcade
« Reply #2 on: July 25, 2006, 03:28:46 pm »
Hey.
Thanks for the reply. Here's the mame.ini
(or is it?)
MKChamp
  • Stil around.
« Reply #3 on: July 25, 2006, 03:39:36 pm »
Looks straightforward. Have you opened up your layout in the editor to make sure the window to display the snaps is artwork1 and not something else?
hartdre
    • NewGame Arcade
« Reply #4 on: July 25, 2006, 04:40:50 pm »
Yup, it should display it. Oddly enough, whenever I use MaeWahConfig, it resets my layout files. Everything is renamed *._mc (I think). But when I rename the files everything goes back to normal.
Thanks,
Drew
(or is it?)
Minwah
    • MAMEWAH
« Reply #5 on: July 26, 2006, 04:53:23 am »
Did you install the system files?  This is required to display PNG's...
hartdre
    • NewGame Arcade
« Reply #6 on: July 26, 2006, 10:59:33 am »
Oh my. Yes, it was the system files. I had to manually install paintx.dll and after that it worked fine. Quite embarassing.
Thanks again,
Drew
(or is it?)
