Author Topic: Buttons how many ?  (Read 17348 times)
teddyboyblue
  • Last login:February 04, 2010, 11:15:49 am
Buttons how many ?
« on: July 23, 2006, 07:11:10 am »
Hi all
I have just started to build my first Mame cabinet and now i am going to make the control panel
Now my question is how many buttons should I have on the control panel ?
I am using an ultimarc I-Pac and a ultimarc Opti-Pac
Best regards
Teddyboyblue
Bones
  • [Moderator]
Re: Buttons how many ?
« Reply #1 on: July 23, 2006, 07:27:40 am »
Players 1 and 2 should each have seven buttons. Players 3 & 4 should each have four. The more admin buttons you can fit on your CP the snazzier it will look.
Anybody who tells you different from the above probably works part-time as a circus clown and circus clowns can't be trusted to make good control panels can they?
teddyboyblue
« Reply #2 on: July 23, 2006, 07:34:06 am »
OK
so far i will make a 2 player CP and i will use 7 buttons for each player
and 3 buttons for the trackball right ?
i will the use 2 for pin Mame
but what about the admin buttons how many should i use there ?
« Reply #3 on: July 23, 2006, 08:56:32 am »
If I were building a standard 2 player MAME cabinet I would use Knievel's exact CP.  Check out his "Woody" thread over in Project Announcements and copy it!
« Last Edit: July 26, 2006, 12:23:33 pm by javeryh »
yalborap
  • Last login:November 05, 2015, 03:19:12 am
« Reply #4 on: July 24, 2006, 08:08:10 pm »
Personally, I'd go up to eight buttons. That way, should you get into the console emulation stuff, you can play everything up to SNES no  problem, amongst other uses.
But that's just me. You might despise everything that's ever touched a home console, and in turn not need that extra button.
severdhed
  • RIP Dinosaur Hippo
« Reply #5 on: July 25, 2006, 08:54:24 am »
on my 2 player cabinet, i have 6 buttons for each player, plus the start buttons.  2 pinball buttons, and 4 admin buttons.  no coin buttons, just the coin mechs.
BlinKY1337
  • Last login:October 25, 2013, 11:06:36 am
« Reply #6 on: July 25, 2006, 12:32:01 pm »
I went with the 7 button neo-geo setup but if I could do it over I would make it 8 for console emulation.
davieboynj
  • Last login:June 16, 2011, 01:32:09 am
  • Eating your legs solves lifes little problems.
« Reply #7 on: July 25, 2006, 01:47:09 pm »
for snes emulation i've never had any problems with a 6 button standard layout:
coin = select (when do you use select anyway?)
1P = start
and the buttons:
 Y X L
B A R
and if you want to use it for neo geo just do:
 B C D
A - -
and move the top buttons a half inch to the right so that the hand feels comfy on ABCD.
If you're emulating a game on an arcade that requires more than 6 buttons you should really be plugging in a controller, as arcades are not conducive for such complicated play (such as holding down triggers and multiple sequences button presses).  By bastardizing the control panel you're only bastardizing your play.
As of right now i only have SNES support for "Super Ghouls and Ghosts".
pointdablame
« Reply #8 on: July 25, 2006, 01:58:32 pm »
42
first off your and idiot
kiddk1
  • Last login:August 01, 2022, 10:58:08 am
  • HAP KI DO
« Reply #9 on: July 25, 2006, 02:43:20 pm »
here is mine, the hole to the right of the 8 buttons at the top now has a 4 way joy in it.
« Last Edit: July 25, 2006, 02:45:27 pm by kiddk1 »
Its easy to like someone,
If you dont know them very well.
teddyboyblue
« Reply #10 on: July 25, 2006, 05:17:48 pm »
Thanks guys for all the input i have decided to go with the Knievel's woody control panel layout  ;D
Is there Any one how can show me how to wire the admins buttons to an i-PAC just so i doesn't do something wrong ma by take a picture
« Reply #11 on: July 25, 2006, 05:27:03 pm »
It's not the best picture but you can see how it's done.  The bottom 4 wires on each side are the admin button wires for player 1 (green) and player 2 (red).
http://photos1.blogger.com/blogger/992/1469/1600/ipac%20partially%20wired.jpg
Here's the finished ipac wiring - I wired 2 sets of controls to each side of the ipac:
http://img73.imageshack.us/img73/6107/p1010338lp8.jpg
« Last Edit: July 25, 2006, 05:28:42 pm by javeryh »
