Author Topic: what is safeLaunch in Mamewah...  (Read 1852 times)
ahmer
  • Last login:March 16, 2014, 02:40:21 pm
  • Do as you like.
    • IC Markets Rebates and Discount
« on: July 23, 2006, 06:22:02 am »
I always easily configure Mamewah...
One thing I don't know about the Mame.INI file in the INI folder of Mamewah...
### Execution Settings ###
emulator_executable                       c:\mame\mame.exe
commandline_format                        [name]{autodosbox}{nosafelaunch}
alt_commandline_format_1              [name]{autodosbox}{nosafelaunch}
alt_commandline_format_2              [name]{autodosbox}{nosafelaunch}
NoDosBox is used to Hide The DOS box in Mamewah...
What is Safe Launch and NoSafeLaunch ?
ahmer
  • Do as you like.
Re: what is safeLaunch in Mamewah...
« Reply #1 on: July 23, 2006, 04:31:31 pm »
Do you gus all Forget Mamewah?
loadman
  • Last login:Yesterday at 07:18:10 pm
    • MaLa
« Reply #2 on: July 23, 2006, 06:23:44 pm »
How hard did you look if you are so anxious to get this info quickly?
FYI: I don't use MameWah but I found this using Google in 5 secs
{safelaunch} - this 'safe launches' the emulator/app, use this if the emulator/app is not launching properly from MAMEWAH,
{nosafelaunch} - this launches the emulator/app as normal (use if possible),
Refer here for futher info:
http://wiki.arcadecontrols.com/wiki/Mamewah_Ini
....Your Welcome   ;)
ahmer
  • Do as you like.
« Reply #3 on: July 24, 2006, 06:57:45 am »
....Your Welcome   ;)
Thanks .... :)
