Author Topic: Set-up: "How to" guide (install and configure emulators, plus Visual Pinball)  (Read 206933 times)
unclet
I have been asked by multiple people (including my favorite Auzzie, who now owes me yet another beer  :cheers:) if I could document how I configured the many emulators I have in MALA.
Well, I always aim to please so I put everything I could think of into the Microsoft Word document.
************* UPDATED **************
User "Gray_Area" asked me to update this post with his v1.8 update.  Click on the following link to obtain his "MalaEmuSetup-v1.8.txt" file.   View it with WordPad.
Get v1.8 here -->
http://forum.arcadecontrols.com/index.php?topic=56010.msg1193926#msg1193926
Get OLDER v1.6 here --> http://unclet.arcadecontrols.com/MalaInfo/MalaEmuSetup-HowTo.doc
« Last Edit: April 19, 2012, 07:28:17 pm by unclet »
loadman
  • Moderator
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
  • Last login:February 02, 2026, 01:49:32 pm
I totally agree!
gamecreature
  • Last login:October 29, 2008, 08:35:37 pm
  • I'm making this up as I go along.
    • Gamecreature
Make your cabinet look its best with custom art from
Gamecreature!
edge
  • Last login:May 08, 2025, 09:08:47 am
  • AttractMode and GroovyArcade rock!
Wow.  Nice job, unclet.  Very comprehensive!  Thank you.
RXII
  • Last login:March 27, 2014, 07:45:51 pm
    • Aussie Lowboy Buildup
Absolutely Fantastic! Got my 1st FE up and running with no problems thanks to this post!
Cheers, Simon. ;)
Operation Aussie Lowboy http://forum.arcadecontrols.com/index.php?topic=68962.0
Soon I may actually be able to play it!
yfdgricker
  • Last login:May 22, 2020, 05:51:37 pm
  • Building my 1st Cabinet Ever!
    • My Mame Cabinet
Whoa! That's alot of words. Slap a yellow and black cover over that document and call it 'Mala Setup for Dummies.'
Really, that is the kind of material I love to see. Very in depth. Thank you for all your time making that document up.
I may be switching from Mamewah to Mala now :) Great job.
BlinKY1337
  • Last login:October 25, 2013, 11:06:36 am
Great write up  :applaud:, malas already one of the easiest FE's to use this just makes it that much better :)
Space Fractal
  • Space Fractal
    • Space Fractal
I would been happy, if this would incoprt into the wiki, like the mamewah faq.  :).
And these sections need also adding infos about each emulators:
http://wiki.arcadecontrols.com/wiki/Game_Consoles
and
http://wiki.arcadecontrols.com/wiki/Handheld_Consoles
There are a lots of missing emulators and how these are cab freidly, or how you can been. I can
unclet
I have no plans on updating the Wiki ...... way too much work for me ...... I rather just dump it into a document like I did ..... however if someone wants to do this, feel free to use the information I provided.
« Last Edit: July 27, 2006, 04:25:05 pm by unclet »
loadman
  • Moderator
    • MaLa
I typed up some details to include
- Zinc
- ePSXe
. It's not as well done as UncleT's masterpeice but it should be adeqate
Let me know if there are any problems
Download here:
[EDIT]
This has been put on the MaLa Help Page
http://mala.arcadezentrum.com/help.html
« Last Edit: September 15, 2006, 07:30:43 am by loadman »
unclet
I have been swamped with work lately so I have not been around much.   Thanks for the information.    I am going to test out the ePSXe stuff when I stuff slows down a bit, hopefully in the next couple weeks......
Anyway, I will add the stuff into the document when I have time and after I test it out.
I read quickly the ePSXe description .......   and have a question.   It seems pretty straightforward to execute based on your description (ie: simply provide a IMG file and off you go), however, I thought the problem with ePSXe (based on my extremely limited reading on the subject) is that each Playstation game needs a different configuration setup.  Is this no longer true ......?    I thought there was a frontend to the ePSXe emulator which might manage the configuration files for you ....  let me know if this no longer applies.
Hey, thanks for the work !
loadman
  • Moderator
    • MaLa
Yeah, Great.  You can double check it and possibly re-word it
The main thing I set up ePSXe was that the preset in MaLa was wrong (too many slashes). It threw TIMOE off track
You may be right. My method may not suit someone who needs/wants different settings for each game (such as keymap).
The few games I played seemed to be OK
« Last Edit: August 19, 2006, 11:36:33 pm by loadman »
  • Last login:February 01, 2026, 01:32:52 pm
I've recently switched over to PSX.  It's lesser known, but what I like about it is you don't have to mess with plugins and all that nonsense, it just works.
The only peculair thing is the command line switches, they are backwards  (come before the isoname).  Also you can switch the virtual pad type (for lightgun games) via the command line.  It has a cd compression tool as well, knocks 20-70 megs off of your cd images.
From what I've tried, it emulates all the games just as well as epsxe, only you don't have to tweak renderers for each game.
loadman
  • Moderator
    • MaLa
Re: MALA "How to" guide (install and configure emulators, plus Visual Pinball)
« Reply #14 on: September 02, 2006, 06:40:10 am »
Thanks Howard.  :D
FYI. A 'How to guide' for MaLa's 'Attract Mode' is now avaliable here:
http://forum.arcadecontrols.com/index.php?topic=57516.0
« Last Edit: September 02, 2006, 07:41:47 pm by loadman »
rubberpoultry
  • Last login:January 05, 2014, 09:32:36 pm
« Reply #15 on: December 15, 2006, 01:14:43 am »
I know this thread is a bit older, but I have a question. I can't seem to create the mame.ini file. I follow the instructions, and I get this error "'mame' is not recognized as an internal or external command, operable program or batch file".
This is where I'm stuck. Can anyone help? I'm running Windows 2k
loadman
  • Moderator
    • MaLa
« Reply #16 on: December 15, 2006, 06:35:03 am »
Questions
1) What version of mame are you running
2) Is in mame or mame32
3) What method did you try
3) What results did you get?
Havok
  • Trade Count: (+17)
« Reply #17 on: December 15, 2006, 07:12:35 am »
As much as it pains me to help a Mala user...
The big question is are you using Mame32, or Mame command line? Mame32 automatically creates an ini file for you on launch, IIRC. If you are using a front end, you should really be using the command line version anyways. Assuming you have the command line version, you need to run mame from a command line with the -cc switch. The error you are getting is most likely due to you not being in the correct directory.
Assuming your Mame directory is located in C:\Mame, you would type the following at a command line, or click on Start, then Run for Windows machines:
C:\Mame\Mame.exe -cc
That's it! A few seconds later, you will have a nice, shiny and new mame.ini file located in your Mame directory.
Enjoy!
loadman
  • Moderator
    • MaLa
« Reply #18 on: December 15, 2006, 07:59:45 am »
Havok
« Reply #19 on: December 15, 2006, 09:04:54 am »
Hehe... j/k
It's all about the arcade love.
rubberpoultry
« Reply #20 on: December 15, 2006, 12:17:40 pm »
I'm a Mac guy so this is all foreign to me. someone in another thread said MaLa was easy to setup.
OK, so anyway... I found the file called mamepp. WHen I entered mamepp -cc in the command promp it created a config file called mamepp. Is that what I needed? Do I need to rename that "mame.ini"?
Havok
« Reply #21 on: December 15, 2006, 12:32:21 pm »
You should be all set. The mame versions will create the ini file based off the executable. So, when you open the mamepp config file, you should see stuff like this:
### MAME.ini ###
### Frontend Related ###
### Windows path and directory options ###
rompath                 roms
samplepath              samples
inipath                 .;ini
cfg_directory           cfg
nvram_directory         nvram
memcard_directory       memcard
input_directory         inp
hiscore_directory       hi
state_directory         sta
artwork_directory       artwork
snapshot_directory      snap
diff_directory          diff
ctrlr_directory         ctrlr
comment_directory       comments
ips_directory           ips
lang_directory          lang
cheat_file              cheat.dat
history_file            history.dat
story_file              story.dat
mameinfo_file           mameinfo.dat
hiscore_file            hiscore.dat
### Windows video options ###
autoframeskip           1
frameskip               0
waitvsync               0
triplebuffer            0
window                  0
ddraw                   1
direct3d                0
hwstretch               1
You enable various options by changing the number from 0 (disabled) to 1 (enabled)
loadman
  • Moderator
    • MaLa
« Reply #22 on: December 15, 2006, 03:39:08 pm »
In MaLa you can also use this (see pic) to edit mame.ini files if that makes it easier for a Mac user  ;D
jWin
  • Last login:December 17, 2014, 01:50:10 am
« Reply #23 on: December 16, 2006, 03:27:42 am »
that configure button never saves the settings for me (winxp),  its always stuck on DirectDraw, I place a check in D3d and it always reverts or stays unchanged.
loadman
  • Moderator
    • MaLa
« Reply #24 on: December 16, 2006, 05:14:12 am »
Oh dear.. That didn't use to be the case.  I assume it's only become a problem with the later versions of mame?  I will alert SWINDUS
unclet
I updated the document (now v1.4) with the new link to the Atari800Win emulator (Atari5200, Atari800XL, etc..) ..... not really a remarkable thing ..... but thought I would mention it ....
loadman
  • Moderator
    • MaLa
any thoughts/objections of someone planting your wonderfull guide onto the Wiki? rather than a link or are you happy to have the guide sit with you?  :D
unclet
If "someone"  ;) wants to then go right ahead ...... the information is there to be shared ... especially now there is a MALA Wiki
« Last Edit: April 25, 2007, 08:12:39 pm by unclet »
unclet
« Reply #28 on: January 14, 2008, 07:59:44 pm »
I updated the document (now v1.5) to correct what seemed to be a wrong "Command Line" setting for the Daphne emulator ..... thought I would mention it ....
  old value = %rom%
new value = "%path%\%rom%.%ext%"
SGT
  • Last login:May 31, 2025, 10:10:32 pm
« Reply #29 on: January 14, 2008, 08:45:57 pm »
unclet,
Your nice tutorials have helped a lot of people.   :applaud:  Have you considered a non-batch file solution to Daphne.  What I mean is, if you name the Daphne frame files to the same name as the respective rom, Mala can launch Daphne games without a batch file.  Just seems like a much cleaner solution.   Do frame files have a standard naming convention; I haven't seen one?  I know Daphne could care less what the frame file is called, and I have see a lot of variety among frame file names.
unclet
« Reply #30 on: January 14, 2008, 09:04:13 pm »
Oh, there are many ways someone can do it ...... the MALA How-To was just to document how "I" did it  (good or bad)  :P
Since my configuration is done, I do not plan on changing since it works fine.
Singapura
« Reply #31 on: January 14, 2008, 09:23:14 pm »
« Last Edit: January 14, 2008, 09:26:37 pm by Singapura »
SGT
« Reply #32 on: January 14, 2008, 09:23:45 pm »
Well that clears that up, thank you.
unclet
« Reply #33 on: January 14, 2008, 09:52:21 pm »
Did not mean for you to take it so hard .....  :P
Just meant that my personal configuration of MALA has already been done for more than a year now and that changing the way it is set up now really would not be worth my effort since everything works as is.  :cheers:
SGT
« Reply #34 on: January 14, 2008, 10:09:09 pm »
I took it hard?  ???  It doesn't really matter to me as I already have it set up.  I was just casually throwing out there that Mala can do the job without creating a batch file for every game.   You're all for making it easy on the newcomers, right?   :angel:
unclet
« Reply #35 on: January 15, 2008, 07:22:13 am »
I was just documenting what I did, which might be easy or hard for the user ....   :cheers:
loadman
  • Moderator
    • MaLa
« Reply #36 on: January 15, 2008, 07:32:35 pm »
 :laugh2:  :laugh2:  :laugh2:  :laugh2:
Anubis_au
  • Last login:January 15, 2023, 10:12:32 pm
  • Ever danced with the Devil in the pale moonlight?
« Reply #37 on: January 15, 2008, 08:17:03 pm »
Hi SGT
Can you post an example of what you did? At the moment I'm still cutting down MAME games to make my "favourtite games" list, and soon, by UncleT's method or another, I will be integrating the Daphne games into my list.
So, if you have a better / easier way, I'd be interested in trying.
Cheers.
SGT
« Reply #38 on: January 15, 2008, 10:26:47 pm »
I don't want to hijack unclet's thread more than I have already.   After this post, I think we should start a new thread.
The process is really very simple.  You just need to name the Daphne frame file to the same name as the Daphne rom (not including the file extension).  Then its just a matter of getting the Mala command line changed.  That is if you are using Mala's other emulators configuration.  If you are using my work-around to combine Daphne and Mame games into the same gamelists, then an appropriate command line must be put into mame.cmd.
When I get my head above water, I'll try to post what I did in more detail or at least PM you with it. Thanks.
Arcade Freak
  • Last login:March 27, 2008, 01:12:06 pm
« Reply #39 on: January 21, 2008, 10:43:02 am »
hi folks,
i am still having problems with setting up mala as per a different tread...
http://forum.arcadecontrols.com/index.php?topic=75493.0
but for here if i include some snaps in the snap directory, how will the FE know which pic to choose from. or am i out to lunch!!!! i want to have a specific picture to show up as you scroll thru the list of games so that my daugther that does not read yet can select the game she wants. then in the option of mala have the pics point to the directory it self...is that correct??
cheers
