Author Topic: Resistors & LEDS & Buttons oh My!  (Read 3365 times)
Brad Lee
  • Last login:May 26, 2005, 11:39:04 am
    • 666
« on: March 12, 2003, 02:40:11 pm »
Are resistors reversible? Meaning are they like diodes that would limit current one way and not the other? Or can they be conencted either way
Also, are 220k 1/4watt the correct size to go between a +5v power supply and a 2.2v LED? Thats the number that keeps popping into my head from reading earlier posts but I can't find anything right now
PacManFan
  • Last login:December 06, 2005, 12:18:56 pm
    • Kymaera Home Page
Re:Resistors & LEDS & Buttons oh My!
« Reply #1 on: March 12, 2003, 02:49:05 pm »
Resistors can be used either way, they do not act like diodes.
I think you need a resistor in the range of 1k - 3k . Anything beyond that will be too dim.
-PacManFan
All Hail Smezznar! The Giant purple centipede of Omnicron 5. Regail him with your odiferous offerings of onion powder!
radiator
  • Last login:April 18, 2013, 07:14:43 pm
  • SFA OK!
    • :: verticalcircle ::
« Reply #2 on: March 12, 2003, 02:49:58 pm »
pretty sure a resistor can be mounted either way...
...not sure about the value for a 2.2v LED though (off the top of my head anyway)
try a search in google for a resistor calculator
When the Germans bombed the British, the British ducked.
When the British bombed the Germans, the Germans ducked.
When the Americans started bombing, everyone ducked!
Birdtales
  • Last login:October 06, 2020, 10:00:31 am
  • You won't like me when I'm angry.
    • Birdtales
« Reply #3 on: March 12, 2003, 02:52:11 pm »
Coming Soon
seaner
  • Last login:October 21, 2003, 02:10:16 pm
    • http://www.beerbot.ca/mame
« Reply #4 on: March 12, 2003, 02:58:03 pm »
resistors will resist current flow in either direction.
To determine the size of resistor you require, you need to know how much current the LED draws.
current = Votage/Resistance
so if your led need 5mA, for example, 1K ohm would do the trick.
Brad Lee
    • 666
« Reply #5 on: March 12, 2003, 03:17:38 pm »
Found it-
http://www.ultimarc.com/ipac2.html
at the bottom of this page is the diagram for leds to an Ipac, so thats where i kept finding the 220 resistors
I will check my switches when I get home for the draw needed and use one of those calcs to figure out theright one
ErikRuud
« Reply #6 on: March 12, 2003, 03:33:29 pm »
Note that the Ultimarc diagram actually shows 220 Ohm resistors, not 220K ohm resistors.
American Laser Games Wrapper
O2em Rom Utility
Carsten Carlos
  • Last login:June 28, 2014, 05:06:25 am
  • Projects: Centipede extended, Asteroids
    • Carlos' Centipede-extended
« Reply #7 on: March 12, 2003, 05:39:34 pm »
The resistors depends on the color and brightness of the LED you wanna use.
Check my homepage under "LED's how to", there is a table of the most common colors and which resistor they need at 5V.
seaner
« Reply #8 on: March 12, 2003, 08:18:53 pm »
That's a bit of a broad statement which may hold true for one family of LEDs.  Some LEDs require much more current than others, regardless of the color.
Brad Lee
    • 666
« Reply #9 on: March 12, 2003, 10:44:59 pm »
Yeah that was my bad, just took a quick look at it and typed it later..
Well according to the calculator it should be either a 300 or 330ohm
The switches are straight off of a Midway panel and are labeled like this:
+=2V MAX
10A 125/250VAC
Carsten Carlos
« Reply #10 on: March 13, 2003, 02:28:50 am »
Of course it is, but if you would have visited the site I mentioned you would have found found much more explanations regarding this and how to calculate it correctly.
I don't wanted to retype this all here - this is were my page is for. Everything there.
Also, notice I wrote color and brightness! Basically you can work with this if you've no idea how much current your superbrightness-LED would need.
