Author Topic: Request for Help with ePSXe and MALA  (Read 11731 times)
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« on: July 21, 2006, 01:46:29 pm »
I'm having trouble setting up the Playstation emulator ePSXe in Mala.
ePSXe works just fine on its own.
All my other emus work just fine using UncleT file tree and set up suggestions.
I have selected the Emulator Presets for ePSXe
and I get the following error message:
* Error loading cdrombin [\"C:\Emulators\RomFiles\playstation\\Blaster_Master.sub\"]
Any suggestions?
loadman
  • Moderator
    • MaLa
Re: Request for Help with ePSXe and MALA
« Reply #1 on: July 21, 2006, 07:02:22 pm »
Looks like another Job for :
unclet
« Reply #2 on: July 21, 2006, 09:15:15 pm »
That is very cool ...... however, Sorry to disappoint ..... Playstation has not yet been configured.  I am running out of harddrive space   :(
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #3 on: July 21, 2006, 09:21:25 pm »
Uh oh, Anyone?
loadman
  • Moderator
    • MaLa
« Reply #4 on: July 21, 2006, 09:25:24 pm »
Watz your address.? I have an old 20 GIG drive if you want it?
Ohhh I'll have a go then  at PSX then  :-)  ...when I get a rom to test it  :-)
Could the two backslashes be the problem?
« Last Edit: July 21, 2006, 11:41:00 pm by loadman »
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #5 on: July 21, 2006, 11:26:05 pm »
I'm not the one who put the two backslashes in.  That was done by the emulator presets in Mala.  I will try it though.
Edit:  It did not work
« Last Edit: July 21, 2006, 11:29:35 pm by Timoe »
loadman
  • Moderator
    • MaLa
« Reply #6 on: July 22, 2006, 12:14:10 am »
Ok between the two of us we will work it out via PM's
And if it tuns out that the MaLa Emu preset needs adjusting I will let Swindus know
loadman
  • Moderator
    • MaLa
« Reply #7 on: July 23, 2006, 06:15:59 pm »
Can you make a game run from a command prompt?
If not then a FE has no chance.
Once you get that happening we can set up MaLa quickly I'm sure :-)
« Last Edit: July 23, 2006, 07:30:13 pm by loadman »
loadman
  • Moderator
    • MaLa
« Reply #8 on: August 08, 2006, 06:30:28 am »
Any suggestions?
Now I have a playstation game file I tested it and have it working very well.
It appears the MaLa 'command line' preset is not quite right for ePSXe ... (Too many back slashes). I will ask for that to be changed for a future version.
It should be:
-nogui -loadbin "%path%\%rom%.%ext%"
Not:
-nogui -loadbin \"%path%\\%rom%.%ext%\"
See attached Pics
Enjoy
« Last Edit: August 08, 2006, 07:19:29 am by loadman »
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #9 on: August 08, 2006, 08:03:46 am »
Wow, that was easy.  It works.  Thank you loadman.
Now I just need to get Zinc going and maybe a game or three in Chankast and I'm set!
loadman
  • Moderator
    • MaLa
« Reply #10 on: August 08, 2006, 09:31:37 am »
No Worries. FYI I used magicISO to convert 'Tony Hawk's PRO SKATER 2' in to a .bin to run from my hard drive
It seems you just need to use Howards Wrapper for Zinc
http://forum.arcadecontrols.com/index.php?topic=56459.msg555059#msg555059
Let me know if I can be any help
« Last Edit: August 08, 2006, 09:34:45 am by loadman »
