Author Topic: Anyone have exact dimensions for Xarcade single player?  (Read 2298 times)
jon
  • Last login:March 15, 2003, 06:01:39 pm
« on: March 11, 2003, 04:57:01 pm »
I am brand new to this forum, and will be starting my first joystick project.  I'de like to build one similar to the xarcade joystick (single player).  Can anyone tell me the dimensions? I am mainly looking for depth of the case itself.
Also anyone know if it is possible to attach suction cups to the bottom of the wood? so that the joystick stays secure while playing.  Are there any alternatives to securing it down only while in use?
thanks
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:Anyone have exact dimensions for Xarcade single player?
« Reply #1 on: March 11, 2003, 04:58:29 pm »
I put velcro at the bottom of mine and then where cordoroys...
rampy
PS i'm looking for the dimensions, be back in a bit...
EDIT and here they are...The X-Arcade
« Last Edit: March 11, 2003, 05:00:13 pm by rampy »
jon
« Reply #2 on: March 11, 2003, 05:00:26 pm »
Wow fast reply, thanks
is there another alternative?  I prefer playing with the joystick on a table or flat surface.  But again it needs to be portable.
rampy
  • *shrug*
« Reply #3 on: March 11, 2003, 05:02:29 pm »
If you make it out of a good heavy wood and use rubber feat i'd imagine you'll be ok...   if not toss a brick into it. or use duct tape (duct tape is brilliant for just about everything)
I'm sure you could work some sort of clamp out like flight yokes and steering wheels use if you were really anal about it.
rampy
