Author Topic: 8-way joystick and a 4-way joystick wired to the same Ipac2 inputs?  (Read 1429 times)
rdowdy95
  • Last login:July 29, 2011, 11:48:50 am
  • This is my rifle.
Have any of you ever wired a 8way and 4 way joystick to the same inputs on an Ipac2?  Like send two wires into the Up, left, right, down.  And they would pretty much control the player 1 side.  If so would I need to put the wires in the input straight or do I need to twist the wires then put them in, and screw them down into the Ipac2?
97thruhiker
  • Last login:October 04, 2014, 01:55:30 pm
Re: 8-way joystick and a 4-way joystick wired to the same Ipac2 inputs?
« Reply #1 on: July 12, 2006, 12:07:35 pm »
Yes, you can wire both the 4 and 8 way into the same inputs on the IPAC.  Thats how I did mine.  You don't need to twist them as the input hole is more then big enough to accept the two wires.
ahofle
    • Arcade Ambience Project
« Reply #2 on: July 12, 2006, 01:17:10 pm »
Yep, I did it too.  No problems and works great.
Zeosstud
  • Last login:January 20, 2026, 05:52:04 pm
« Reply #3 on: July 12, 2006, 05:19:22 pm »
Same Here.. Not a Problem.
