Author Topic: Ms. Pacman Jakks Wiring - Help?  (Read 1284 times)
shawnzilla
  • Last login:May 05, 2022, 12:01:55 pm
« on: July 11, 2006, 03:17:24 pm »
I'm attempting to wire a Ms. Pac Jakks controller into a control panel. I wired everything up, and it comes on, but the only button that works is the Reset button. Nothing else responds, including the joystick. I have everything wired to a common ground, so the grounding is definitely in place. Any suggestions? The only thing that has no connection is a pink wire labeled "VDD" (the one in the same row as the joystick & button inputs).
Has anyone else encountered this issue? Any thoughts or suggestions?
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
Re: Ms. Pacman Jakks Wiring - Help?
« Reply #1 on: July 11, 2006, 05:41:55 pm »
Is this the wireless or wired version? If it's the wireless, PM me and I'll send you the information I have on it.
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
shawnzilla
« Reply #2 on: July 11, 2006, 05:47:01 pm »
Wired version. And I noticed something a little strange. The reset button works whether or not it is hooked into a ground or not. Is that particular circuit grounded with the power button? If so, do I need to run the rest of the controls to a different ground?
shawnzilla
« Reply #3 on: July 11, 2006, 10:50:49 pm »
Figured it out...it was the one marked "VDD"
