Author Topic: How to find which line is which in a VGA cord?  (Read 1011 times)
rackoon
  • Last login:January 05, 2026, 12:26:30 pm
  • I EAT PENCILS!
« on: July 08, 2006, 05:29:03 pm »
Heres the deal. I got a arcadeVGA card from ultimarc on one side and a monitor on the other.
The VGAcard has a 15 pin out put and my monitor has a 9 pin input. I have a list of what pin is what for both, BUT!
PROBLEM: I want to buy my self a 15 pin VGA cord and cut it and wire on a 9 pin plug on the end but I dont know how to identify which line is which when I cut it apart.
I have a multi meter. Is there a way to use it to find what line is which pin?    :dizzy: :banghead:
They treated me like an animal and that's what I became.
Kevin Mullins
    • Me on Myspace
Re: How to find which line is which in a VGA cord?
« Reply #1 on: July 08, 2006, 05:56:54 pm »
Use the continuity or diode setting. (with audible beep if you have it)
Touch the two leads together and you should get something like .000       (beep)
Hold one lead on a single cut wire and touch each pin  on the the other end until you find it.
« Last Edit: July 08, 2006, 05:58:26 pm by Kevin Mullins »
rackoon
  • I EAT PENCILS!
« Reply #2 on: July 08, 2006, 07:07:45 pm »
Thanks, I knew it was going to be somthing like that. I will give that a shot. :cheers:
