Author Topic: Kitchen Faucet Repair  (Read 7827 times)
2600
« on: July 06, 2006, 09:11:19 pm »
Seems like a simple repair, but I don't have it quite right.
I have a standard kitchen faucet where you pull the handle up to turn the water on, turn it right for hot, left for cold.  I replaced the cartridge to stop a leak and that worked fine.  Now, I have a new problem.  I can turn the water and it's nice and smooth, but turning it off requires finesse.  You have to really make sure it's all the way down.  Just a little bit up and the water starts running.  I thought I put it back together correctly, but must be missing something obvious.
Any thoughts?
missioncontrol
  • MC-Retro says Wot!
  • Trade Count: (+13)
Re: Kitchen Faucet Repair
« Reply #1 on: July 06, 2006, 11:43:36 pm »
that's why I find it so much easier to replace the whole faucet rather than a part inside the faucet.....
CCM
« Reply #2 on: July 07, 2006, 02:22:22 pm »
I had a similar problem a while back.  I just went to a hardware store and bought a  kitchen faucet repair kit and relapced all the springs and washers, and it worked like a charm.
http://plumbing.hardwarestore.com/51-286-faucet-repair-parts-kits/delta-faucet-internal-parts-kit-121442.aspx
2600
« Reply #3 on: July 07, 2006, 02:43:49 pm »
No springs in mine.  I replace the 2 O-rings at the same time as the cartridge, moen 1225.
The handle seems to have a little play and I may be missing a washer.  Don't recall seeing a washer, but going to try that first.
J_K_M_A_N
« Reply #4 on: July 07, 2006, 03:32:36 pm »
Just an FYI...As was the case at least a few years ago, both Moen and Delta had numbers you could call for free parts. Moen's is 1-800-BUY MOEN and Delta's is 1-800-345-DELTA. I am not sure if the parts are still free but they used to be. I know those Moen 1225's and 1222's are pretty spendy. You will need a model number. It may not be free for Home Depot versions though. This was when I worked in the plumbing wholesale business. It would be worth a try.
J_K_M_A_N
Stingray
« Reply #5 on: July 07, 2006, 04:09:48 pm »
Yeah, me too.
-S
