Author Topic: need advice on breaktime sitdown cabinet button locations  (Read 1025 times)
arcadepcnut
  • Last login:August 15, 2019, 12:03:07 pm
  • Warhammer 40K, you should try it.
    • BREAKTIME
« on: July 06, 2006, 06:56:28 pm »
Here is my cabinet
http://www.nnmodels.com/breaktime/
Since im converting the xbox steering wheel to happ arcade controllers I have an issue with the buttons that were normally on the steering wheel....6 of them and the d-pad that is in the center of the steering wheel has to go somewhere. however I want to keep the machine as clean as possible. So an arcade 8 way stick sticking out of the dashboard might be out of the question.
any suggestions?
« Last Edit: July 07, 2006, 08:33:20 am by arcadepcnut »
severdhed
  • Last login:December 14, 2024, 05:01:52 pm
  • RIP Dinosaur Hippo
Re: need advice on breaktime sitdown cabinet button locations
« Reply #1 on: July 07, 2006, 02:24:53 pm »
how about create a flip down panel, like a glove box in a car.  Looks like there is room to the left of the wheel.   i made a quick little diagram since i suck at explaining.  not to scale obviously, but it gets the point accross
arcadepcnut
    • BREAKTIME
« Reply #2 on: July 07, 2006, 10:03:35 pm »
i like. I like alot. Im goign to run with this idea. The xbox is located on the left side of the dash and the shifter on the right but I will hopefully come up with something. in a real car the driver controls are mostly on the right side so Im going to see what I can come up with using your idea as a template.
  • Last login:Yesterday at 09:36:48 pm
« Reply #3 on: July 07, 2006, 11:32:09 pm »
Is it me, or is this diagram amazing? Well done!
I request a dancing girl - preferably bikini - extra preferably thong!
